This question is related to these others: mostly this one, but also this one and this one.
Do we care about CFTs in particle physics? Let me explain. Suppose we don’t know anything about string theory, holography, etc. And suppose we don’t know about the Wick rotation, so that we are unable to relate QFTs and statistical field theories. In this hypothetical world the only application of QFT is the Standard Model and its different extensions or possible minor changes. Would we be interested in CFTs? Why?
I'm asking this because I want to motivate the study of CFTs from the point of view of standard QFTs. The best argument I've found is that all "reasonable" QFTs are actually points in the RG flow from a fixed point at high energies $\text{CFT}_\text{UV}$ (UV completion) and a fixed point at low energies $\text{CFT}_\text{IR}$ (see for instance these lectures by Simmons-Duffin). Is the Standard Model an example of this? Looking at the running couplings of the SM, my answer would be no. Look for instance at this article by Rychkov. There he says there are basically three types of IR phases:
  • A CFT.
  • A theory with a mass gap. The example is QCD, because the beta function is negative and the coupling blows at low energies.
  • A theory with massless particles. The example is QED, because it is free in the IR, and at energies $E \ll m_e$ you're only left with photons. Someone said in the comments that this is a CFT (an empty CFT, with just the vacuum state for electrons) but Rychkov doesn't consider it as such.
So at least QCD is a counterexample of the above notion: it has no CFT$_\text{IR}$. On the other hand, for the UV part QED gives a counterexample: its coupling constant grows towards the UV, so it has no $\text{CFT}_\text{UV}$. Is this reasoning correct? If it is, then why are the only real-world QFTs (QED and QCD) a counterexample of such an extended notion (that all QFTs are points in the RG flow between two fixed points)? The "good" (conformal) behaviour of QCD at high energies (and arguably QED at low energies) seems accidental, not fundamental. So why do we care about CFTs in particle physics?
MBolin
  • 1,214
