Arnol’d in his Ordinary Differential Equations, states that
The propagation of heat is a semideterministic process: the future is determined by the present but the past is not.
How is this so? If there is a differential equation to determine the future, can’t we use the same equation to backtrack the past?
Atom
  • 1,999
I did not check the reference, so I may be missing something.
However, here is what I think. Many different "pasts" can lead to the present solution, and there is only a single far future.
Take a metallic rod in a room at temperature $T_\text{ambiant}$. No matter where nor by how much you heat it, the final state (which theoretically is never reached but in practice is) will be the same: the rod will have an homogeneous temperature, that of the room $T_\text{ambiant}$. From that state, you cannot go back and guess how the initial temperature was.
In your question you mention to use the same equation to backtrack the past, but you cannot do that. The equation contains an initial condition, and this part differs if you start in the final state compared to starting in an earlier state. So while the heat equation that describes the dynamics of the temperature change is the same in both cases, the initial conditions aren't the same. And it turns out that infinitely many different prior states can lead to the same present (or future) states.
Clarifying my last paragraph a bit more, as suggested in a comment. Take the rod again, this time we take a snapshot of the temperature distribution. We notice that the temperature is uniform and the same everywhere. From this, we cannot conclude that this was always the case. In fact, it could be that it was always like that, that the rod is in thermal equilibrium. But there is also infinitely many possibilities that lead to this state, for example if the rod was heated anywhere by any (reasonable) amount. The two totally different initial conditions lead to the same final state.
If the snapshot shows a Gaussian-like temperature distribution, you cannot know whether it is due to a Dirac delta-like initial perturbation from an otherwise uniform temperature distribution that lead to this state, or whether the rod was heated all along its length in such a way as to make a Gaussian-like temperature distribution. Here again, we have a present state, but we cannot know what prior states lead to the present state. However we do know how the present state will evolve, thanks to the heat equation and our initial conditions (the snapshot temperature distribution).
Another perspective is that the heat equation is not invariant under time reversal. It means that if one changes $t$ to $-t$, then the heat equation is not valid anymore. In other words, it is not able to describe the dynamics of the evolution of temperature when time goes backward. From that perspective, one can realize that one cannot retrieve information about the past, i.e. one cannot describe how the temperature changed with time to arrive at a particular temperature distribution.
