Suppose you have saturated steam entering a turbine. If the turbine condenses the saturated steam to saturated liquid water and uses the heat of vaporization to do useful work, we say that this process violates Carnot's efficiency or the second law of thermodynamics. This is because we are undergoing a phase change at constant temperature. Therefore, $T_h=T_c \implies \eta _{Carnot} = 1-\frac{T_h}{T_c} = 0$.
However, the same process can happen in a condenser and we say that the condenser simply expels the rejected heat.
I have two questions:
  1. Can a turbine thoeretically extract more work from steam coming at $T_h$ by utilizing the heat of vaporization and more by discharging the outlet stream at a lower temperature $T_c < T_h$? I understand that water formation inside the turbine is extremely detrimental to it, but can a turbine possibly do this?
  2. Why does a condenser not violate Carnot's law of maximum efficiency?
