I've heard about using particle accelerators to shoot particles a specific distance into a wafer to split it and it got me thinking, can we do the same with sounds? Link to a page talking about the particle acceleration method: https://www.theatlantic.com/technology/archive/2012/10/cutting-silicon-with-a-proton-accelerator-instead-of-a-saw/264176/
Would it be possible to generate a high frequency standing wave (or pulse) inside the wafer in such as way that the crystal cracks and forms a "perfect" flat surface?
I'm hesitant to this being possible because of the massive size difference between the crystalline atomic structure and "common" ultrasonic waves. But since we are talking about a solid here one should be able to use extremely high frequencies, right?
Once a layer in the crystal has cracked, would this not create a stress point and the crack would continue along this layer, giving you very flat surface even if the force was not applied completely uniformly?
And any possible attenuation could be used as an advantage by applying the wave directly to the surface you want to cut, only exposing a small part of the wafer to the strong waves, possibly even eliminating the need for some sort of standing wave configuration to make a precise cut.
Anyone knows if this is possible or even being done?
