Yes. As long as you obey the symmetries of the Standard model (for example, in this case you have already made sure to conserve elecrtic charge) and have enough energy, any production is possible. To see the kinetic energy you need, simply open up your Particle data group booklet and look up the mass of the charged pion and the proton. You see that it is 140 MeV and 938 MeV respectively. Now you need to conserve both energy and momentum. Following the same calculations as in
Pion production in proton-proton collision
but changing the $\pi^0$ to two $\pi^\pm$ we then have
$E_p = m_p + 4m_\pi + \dfrac{2m_\pi^2}{m_p} = 1540 \text{ MeV}$
$E_{p, \text{kin}} = E_p - m_p = 602 \text{ MeV}$
Here we used the fact that $\pi^+$ and $\pi^-$ have the same mass. It is however unlikely that you will create them at this energy, the likelyhood will increase with higher energy as the pions have more possible final states (more possible different values of their momenta). Also, it is much more likely to create neutral pions than charged pions in general, nature likes to keep things neutrally charged if possible.
