The gas molecules in air do indeed interact with each other, by colliding against each other with surprising speed at room temperature. This means a volume of gas will possess compliance (it can act like a spring). Those gas molecules possess mass too, and hence a volume of air can transmit compression waves through it at a speed that depends on this characteristic compliance and mass, and as a transmissive medium free air in an open space will therefore possess a certain characteristic impedance.
Now the air inside a tube possesses a certain characteristic impedance for waves traveling long its length as well, but this impedance is different from that of free air, which means there is a significant impedance mismatch at the open ends of the tube. When an acoustic wave in a tube meets that mismatch, part of the wave gets reflected off the mismatch (with a 180 degree phase reversal) and travels backwards up the tube, and part of the wave escapes into free space.
The fact that this reflection occurs off the open ends means that even a tube with two open ends will still support a resonance.
