Every star or other massive body in the universe rotates, if only a little. If such a body collapses, its spin, any spin at all, and thus, angular momentum approach infinity as r approaches 0. Angular momentum must be conserved. In order to produce a true singularity or a non-rotating black hole, there must be some process by which ALL angular momentum (energy) is dissipated or converted to something else.
Is there such a process? Otherwise all black holes must rotate, perhaps too fast or too slowly for us to detect, but they must rotate. Am I missing something? I've never heard this discussed before.
There are, to our knowledge, no non-rotating black holes (or other massive bodies).
Perhaps you have heard something like the Schwarzschild metric being discussed. The Schwarzschild metric was discovered in 1915 and is a solution to non-rotating bodies. It is a useful approximation for describing slowly rotating astronomical objects, including Earth and the Sun. It is also much simpler to solve for non-rotating bodies than for rotating bodies.
However, the Kerr metric is a generalization of the Schwarzschild metric and describes a solution for a rotating black-hole. This solution was not discovered until 1963. An extension to this solution, the Kerr–Newman metric, was discovered shortly thereafter in 1965.
Mick
  • 999
