I don't understand why we use this formula:
Instead of this formula:
I mean, why we ignore $\omega\cdot t$ part.
If you use the real representation
$$E\left(x,t\right)=\dfrac{1}{2}E_{0}\cos\left(kL_{1}-\omega t\right)+\dfrac{1}{2}E_{0}\cos\left(kL_{2}-\omega t\right)=E_{0}\cos\left(k\dfrac{L_{1}+L_{2}}{2}-\omega t\right)\cos\left(k\dfrac{L_{1}-L_{2}}{2}\right)$$
The oscillations in time of an electric field in the optical domain are so fast, our eyes and also electronic detectors just can't catch them. What you actually see is the time average of the intensity $I=\left<\left|E\left(x,t\right)\right|^{2}\right>_{t}$. Since $\left<\cos^{2}\omega t\right>=\frac{1}{2}$ over one period of oscillation, you get
$$I=\left<\left|E\left(x,t\right)\right|^{2}\right>_{t}=\dfrac{1}{2}\left|E_{0}\right|^{2}\cos^{2}\left(\dfrac{k\Delta L}{2}\right)=\dfrac{1}{4}\left|E_{0}\right|^{2}\left(1+\cos\left(k\Delta L\right)\right)$$
As you can see, including time just gives you an additional numerical factor and doesn't change the spatial interference pattern. Therefore, in most calculations you just ignore it.
eranreches
  • 4,249
So why did you not ask this question when the double slit arrangement was being discussed and the positions of maxima and minima were found?
In both cases you need to find the resultant at a certain position of two superposing waves which have the same frequency, $\omega$, but differ in phase (and amplitude).
The resultant wave at the position in question will have the same frequency as the two superposing waves and an amplitude which depends on the phases (and amplitudes) of the superposing waves.
This is equivalent to saying that $e^{-i\omega t}$ is common to each term in the equation $\mathcal E^{\rm out}= \mathcal E_1 + \mathcal E_2$ and can be cancelled out.
Farcher
  • 104,498
