I studied that to get the lasing conditions gain must overcome the losses. But what are the losses? Thanks a lot
Luigi2405
  • 153
The main ones are:
  • Mirror losses. No mirror is 100% reflective. Even if there were, if you used 100% reflective mirrors on both ends, your laser would have no output beam.
  • Scattering in the beam path, or material absorption in the beam path.
  • Diffraction. The beam spreads as it travels, so there is some light that simply falls outside the area of the mirrors.
  • Any light you pick off to monitor the beam strength.
The Photon
  • 29,651
The significant losses in laser comes from
  • the reflection loss of the grating (wavelength selective);
  • resonance losses between R1 and R2;
  • material attenuation and
  • nonradiative combinations
Haris
  • 710
