I don't know much about superfluidity, but I think I can explain a little bit about the statement of no Goldstone bosons in two dimensions.
Goldstone modes always show up in a semiclassical expansion, because they simply follow from general considerations about the effective potential. If you write down the most general potential consisting of only operators relevant in the infrared invariant under whatever continuous symmetry you like, its minimum set will be some $G/H$ coset manifold that the Goldstone modes live in. Since symmetry bans a mass term for them, they will remain massless to all orders in perturbation theory. Moreover, by integrating out the massive modes of the original field, one obtains an effective action for the Goldstone modes, which is dictated by symmetry to be a nonlinear sigma model on the target manifold $G/H$.
In $d > 2$, the nonlinear sigma model is purely nonrenormalizable and has no relevant perturbations consistent with the symmetry of the problem. Therefore, one can conclude that the semiclassical description of the low-energy dynamics is good, and in fact increasingly good at low energies by RG improvement. Therefore, the Goldstone bosons are real, and we can identify them with the ones that show up in the perturbative expansion.
In $d=2$, the action is classically conformally invariant so there is a question as to what happens when we turn on fluctuations. In the cases relevant to spontaneous symmetry breaking the sigma model is asymptotically free and some strong-coupling dynamics takes over in the infrared, which causes the true description of the theory at long distances to be in terms of some new collective fields with gapped excitations.
This is the general story, but there is an interesting counterexample when the target of the sigma model is $U(1)$. In this case, the low-energy theory is a free field theory and it appears that there is no dynamical way for the Goldstone bosons to die. The point is that the would-be Goldstone field $\theta(x)$ is circle-valued, so it is not a good local operator in the field theory. So there is "no Goldstone boson"--the well-defined operators are things like $e^{i \theta(x)}$ which respect the circle-valuedness. One can show by cluster decomposition that $\langle e^{i\theta(x)} \rangle = 0 $ which means that there is no symmetry breaking, and therefore no associated Goldstone bosons.
Hope this helped!
