The search based on the term "Twin Paradox" gave (today) 538 results.
In all the answers, the answerers explained the phenomenon by referring to arguments sort of falling out of the framework of special relativity. I saw answers referring to acceleration and deceleration, changing coordinate systems, etc. Even Einstein referred to General Relativity when explaining the TP...
THE QUESTION
Is it not possible to explain the phenomenon purely within Special Relativity and without having to change the frame of reference?
EDIT
... and without referring to acceleration and deceleration, without having to stop and turn around or stop and start again one of the twins?
zoli
  • 61
It is possible to obtain the correct answer to the amount of time accumulated by either of the twins by using any single reference frame, without changing that frame at any point in the analysis. Whether or not such a calculation constitutes an “explanation” is a matter of opinion. I would tend to say “no” because the “paradox” is precisely about what happens when you incorrectly change reference frames.
To obtain the amount of time accumulated by any traveler we write their worldline as a parametric function of some parameter (using units where c=1), for example $r(\lambda)=(t(\lambda),x(\lambda),y(\lambda),z(\lambda))$ where $r$ is the worldline and $t$, $x$, $y$, and $z$ are the coordinates of the traveler in some reference frame whose metric is given by $d\tau$. Then, for any reference frame for any spacetime for any traveler, the amount of time is given by $\Delta\tau=\int_R d\tau$ where R is the total path of interest (i.e. all of the $r(\lambda)$ of interest). Because this is a completely general formula it applies for an inertial traveler or for a non inertial traveler, it also applies for an inertial reference frame or for a non inertial reference frame, it also applies in the presence of gravity or not.
For the specific case of an inertial frame we have $d\tau^2=dt^2-dx^2-dy^2-dz^2$ from which we can easily obtain $$\frac{d\tau}{dt}=\sqrt{1-\frac{dx^2}{dt^2}-\frac{dy^2}{dt^2}-\frac{dz^2}{dt^2}}=\sqrt{1-v^2}$$ So then $$\Delta\tau=\int_R d\tau=\int_R \frac{d\tau}{dt} dt = \int_R \sqrt{1-v^2} dt$$
Note, this last paragraph assumes an inertial frame (any inertial frame is the same). The usual mistake is to use the inertial frame expression in a non inertial frame. A similar procedure can be used in a non inertial frame, but you must use the appropriate expression for $d\tau$
Dale
  • 117,350
In Minkowski space, the worldline of one twin is a geodesic. The worldline of the other is not, although it can be approximated or idealized as piecewise geodesic. This asymmetry explains why there is no paradox.
If both worldlines were geodesics, then the twins would never meet again.
user52817
  • 359
I believe that in search for a better explanation, it is best to turn to the Lorentz ether theory. It is often said, that this theory is empirically equivalent to the SR. Since the same mathematical formalism occurs in both, it is not possible to distinguish between LET and SR by experiment. The introduction of length contraction and time dilation for all phenomena in a "preferred" frame of reference, which plays the role of Lorentz's immobile ether, leads to the complete Lorentz transformation
It should be noted, that there is no "paradox" related to the Lorentz theory. In the Lorentz theory, the paradox that has arisen in the depths of special relativity is resolved by means of elementary algebraic methods, staying within the same frame of reference and not taking into account the acceleration or deceleration.
Let's consider resolution of the "paradox" in the framework of the Lorentz theory.
1) Let’s consider what would happen if one of two twins who are at rest in the ether at one point, flies at speed $v$ to a distant point and then after a while returns to twin $A$ remaining at rest.
If for the twin flying in the ether his “local time” characterizing the rate of physical processes in his body and the pace of the movement of his clock on both segments of his flight (there and back) slows down due to interaction with the ether, then the lapse of his “local time” will be $1/\sqrt {1-v^2/c^2}$ times less than for the twin at rest in the ether, and the “travelling” twin will get less “old”. The turn of the travelling twin, provided it is virtually instantaneous, has no practical effect on the ratio of times of both twins.
2) Now let's calculate, what will happen if the two twins are flying side by side in the ether at speed $v$ – with their “local time” passing slower – then one of them stops, staying at rest in the ether for some time, then catching up with the travelling twin.
The twin who continued his flight in the ether with no information about the fact of his motion in the ether perceives this maneuver of his brother as a round trip to a distant point.
An obvious answer is that, since according to the ether theory after the twin’s stop in the ether his time will pass faster than the “local time” of his twin brother who continues his flight, and then when the twin stopping in the ether after some time catches up with the missing brother, he will age more than the latter. The “local” time of the twin catching up with his flying brother will actually flow slower than for the flying brother. This is due to the faster speed of the twin catching up with his brother. As a result, the brother making a stop in the ether will age not more, but less than his twin brother who has not interrupted his flight.
Let us demonstrate that if the proper times of the motion there and back of the non-inertial twin relative to the inertial twin are equal, then for the non-inertial twin it will take $1/\sqrt {1-v^2/c^2}$ times less time than for the moving inertial twin, and the non-inertial twin will age less.
Let at the time of stop of one of the twins in the ether the clocks of the parting twins show zeros. Suppose that after making a stop for some time, the twin who has lagged behind, at the moment $t_1$ of the ether time when his clock (because of the stop) was showing this time, left at speed $u$, such that $v<u<c$, following his brother flying away from him. The distance between the twins at the start of the twin who has left behind is equal to $vt_1$. Setting out, the twin left behind will catch up with the twin flying at a constant speed $v$ at the point in time $t_2$, having spent the time equal to $vt_1/(u-v)$. During this period, by the clock of the twin following the flying away brother at speed u, there will be a lapse of proper time, which is $1/\sqrt {1-v^2/c^2}$ times less than the ether time and equals $vt_1\sqrt{1-(u/c)^2}/(u-v)$. Let us assume the velocity $u$ such that the proper time $t’_2-t’_1$ of the catching up twin is numerically equal to the time $t_1$ of his stay at rest relative to the ether, i.e. $t’_2-t’_1=t_1$ or
$$t_1=vt_1\sqrt {1-(u/c)^2/(u-v)} (1)$$
This equation meets the condition under which the twin spends the same proper time on a trip to a distant point and back. By elementary transformations of the equation (1) we can obtain the value of velocity $u$, which is equal to $\frac {2v}{1+(v/c)^2}$ . Substituting this value in the expression for the time $vt_1/(u-v)$ required for the return of the twin, and summing the time $vt_1/(u-v)$ and the time $t_1$, we obtain the ether time spent by the lagging behind twin on the stop and return to the flying twin. This time is equal to $2t_1/(1-v^2/c^2)$. Since the clock of the inertial twin flying at a speed $v$ go $1/\sqrt {1-v^2/c^2}$ times slower than the clock at rest in the ether, the flying twin will determine the time spent by the lagging behind twin on the stop and return to the flying twin as a quantity meeting the equality:
$$t’_2=2t_1/\sqrt {1-(v/c)^2}$$
Since the time elapsed for the non-inertial twin by the moment of his return is numerically equal to $2t_1$, and the time of the inertial twin is numerically equal to $2t_1/\sqrt{1-(v/c)^2}$, then the lapse of time for the non-inertial twin is $1/\sqrt {1-v^2/c^2}$ times shorter, and he has aged less than the inertial twin has.
This way we can see, that non–inertial twin (or clock) will show $1/\sqrt {1-v^2/c^2}$ less time than inertial one, despite of direction of its motion in ether.
We get absolutely the same result as in the Special Relativity, but resolution of the paradox is very simple.
It's possible that the twin paradox is the most misunderstood thing on the internet. First, there are those who claim it isn't a paradox when they mean it's not a contradiction. Rest assured it is a paradox, it is several paradoxes, and at the end of the day, it is the Andromeda paradox.
Step one in understanding it is make it as simple as possible, where twin A stays at home, and twin B travels. (If you stumble on a explanation where B stays at home: keep clicking).
Ignore gravity and acceleration problems: twin B flies straight out, and straight back. Keep it simple. Pick a nice $\gamma$, let's do $\gamma=10$. For 100 year legs.
Paradox 1: Is that twin B is younger than twin A at the end. Fine, that's time dilation. A paradox in 1905, not in 2019.
Paradox 2: Is that all motion is relative. So A see's B's clock run slow (see paradox (1), but B also sees A's clock run slow. That's weird:
A ages 100 years outbound, 100 inbound. He sees B ages 10 + 10. B experiences 10 + 10, but sees A age only 1 year on each leg (1 + 1). A paradox, indeed. Many will claim acceleration or GR at this point.
Paradox 3: Of course the resolution of (2) is that A instantly ages 198 years when B changes directions. This isn't acceleration or GR, because in both A and B's frames, the turn around takes ZERO time, so NO amount of time dilation can fix it. $0 \times \gamma' = 0$, after all.
A sees B change direction instantly, and the only change for him is that he computes B's definition of "now on Earth" going from 49 years in his past to 49 years in his future.
Meanwhile, B turns around in zero time. The only difference is that his definition of "now on Earth" (which is well outside his light cone) jumps forward 198 years...and that accounts for ALL the aging difference. That pretty much is the Andromeda paradox.
JEB
  • 42,131
