The way to understand why 6-Li has $J^P = 1^+$ ($J$ the toal angular momentum and $P$ the parity) is through the measure of its magnetic momentum,
\mu^{exp} \simeq 0.88\mu_N
Where $\mu_N$ is the Bohr's magnetic momentum.
This result can be understood assuming that 6-Li behaves as an alpha particle plus a deuteron. The alpha particle has $J^P = 0^+$ so taking $\mu^{exp}$
as the mean value of the magnetic momentum operator of the remnant deuteron one has
\mu^{exp} = \langle \mu \rangle = \langle \sum_{p, n}g\mu_N J_z \rangle = \sum_{p, n}g\mu_N m_J = (2·2.79 - 2·1.91)m_J\mu_N \equiv 0.88\mu_N
\tag1$$
$m_J$ is the eigenvalue of $J_z$, $\sum_{p, n}$ is the sum over the deuteron's proton and neutron, $g[p] = 2·2.79$ and $g[n] = -2·1.91$. Since from the point of view of Nuclear Physics -nuclear shell model- there is no difference between $n$ and $p$, we can assume that $p$ and $n$ contributes equally as $m_J = +1/2$ and with this value you can see that Eq. (1) is fullfilled. Now, only with this, you could say that $J$ is zero or 1.
Nevertheless, you know that isospin of deuteron is null (see below) wich means that this part of the wave function is antisymmetric. The rest of it must be, therefore, symmetric: spatial plus $J$ parts. For the spatial one we can select $L = 0$ wich implies symmetric spatial state and positive parity
$$P = (-1)^L = +1$$
Finally, $J$ part must be symmetric, i.e., $J = 1$
Therefore,
^{6}Li \sim \alpha +\ ^{2}_1H
Deuteron's isospin equals to zero, $T = 0$
For $T = 1$ you have the triplet while for $T = 0$ the singlet isospin state,
\cases{
T = 1: \ pp, nn, (pn + np)/\sqrt{2}\ \leftarrow\ symmetric\ states\\
T = 0: \ (pn - np)/\sqrt{2}\ \leftarrow\ anti-symmetric\ state
Since we are considering isospin symmetry, all triplet states have (up to electromagnetic corrections) the same energy and therefore they are equally probable to exist in nature. But we have not seen $pp, nn$ nucleous so for deuteron the isospin state must be the singlet, which is anti-symmetric.
