I get that Earth's mass is very large, so its acceleration is very tiny. But wouldn't the acceleration accumulate over a period of time and become noticeable?
It seems you have the same misunderstanding like most people have before fully understanding Newtonian physics. They think: Only the moon rotates around the earth, and the earth stands still. But this is wrong.
Actually the earth does accelerate towards the moon, in much the same way as the moon accelerates towards the earth.
And that's why not only the moon, but also the earth rotates around their common barycenter (the $\color{red}{+}$ in the animation below), albeit with a smaller radius.
(animated image from Wikipedia: Barycenter - Gallery)
Edit (in reply to question asked in comment, now moved to chat):
The attractive force is pointing vertically down to the center of the earth. It has no horizontal component. Therefore this force adds no horizontal speed to the moon's movement. The moon had already a horizontal speed since its creation billion years ago. The attractive force acts only vertically. Therefore the moon's path is a curve bending towards the earth, instead of just a straight line.
The same applies to you when standing on the earth. The attractive force adds no horizontal speed to your movement, And since you had no horizontal speed from the beginning, it stays like this.
- 42,352
It does: both the Earth and the Moon accelerate towards each other all the time. As you say, the acceleration of the Moon is significantly larger than that of the Earth. Both bodies, therefore, end up following trajectories for which the acceleration is always towards the other: those trajectories, of course, are the orbits they take around a common point, which is the barycentre of the Earth-Moon system. This is the centre-of-mass of the system, and for a two body system of masses $m_1$, $m_2$ the distance of the centre of the $i$'th body from it is given by
$$d_i = r\frac{m_j}{m_i + m_j}$$
where $r$ is the separation of the centres of the bodies, $i,j\in\{1,2\}$ and $j\ne i$.
If you take the Earth-Moon system and assume the orbit is circular (which is a pretty good approximation I think), then for Earth we get $d_1 \approx 4671\,\mathrm{km}$, which means the Earth is orbiting (and hence accelerating towards) a point about that far from its centre. This point is inside the Earth, sine the radius of the Earth is about $6371\,\mathrm{km}$.
By contrast, for the Pluto-Charon system, the barycentre is outside Pluto, and the bodies can be clearly seen to be orbiting a common central point: the Wikipedia page for barycentre has a rather nice little animation made up of images from New Horizons which shows this.
'Accumulation of acceleration'
I wanted to address the other notion, that acceleration somehow 'accumulates'. This is true, in the sense that the velocity of something is the integral of its acceleration over time:
$$\vec{v}(t) = \vec{v}(t_0) + \int\limits_{t_0}^t \vec{a}(\tau)\,d\tau$$
But the critical thing here is that $\vec{v}$ & $\vec{a}$ are vectors, which means we can arrange life so that this integral does not become very large, even if the magnitude of the vectors is never zero (indeed, even if it is constant).
So the obvious example is to think about an acceleration like this, in cartesian coordinates in 2 dimensions:
$$\vec{a}(t) = (a\sin\omega t + a\cos\omega t)$$
We can integrate this to get $\vec{v}(t)$ (dropping the constant of integration which we can safely do as it involves a change of frame):
$$\vec{v}(t) = \left(-\frac{a}{\omega}\cos\omega t, \frac{a}{\omega}\sin\omega t\right)$$
And we can integrate again to get the position, $\vec{p}(t)$, again dropping the constant of integration which corresponds to a choice of origin of coordinates:
$$ \begin{align} \vec{p}(t) &= \left(-\frac{a}{\omega^2}\sin\omega t, -\frac{a}{\omega^2}\cos\omega t\right)\\ &= -\frac{1}{\omega^2}\vec{a}(t) \end{align} $$
Well, now, this is motion in a circle, of course, and importantly, the magnitude of the acceleration, $|\vec{a}(t)| = a$: it's constant. And the direction of $\vec{a}(t)$ is always towards the centre of the circle.
This is what is going on in orbiting systems: the bodies are continually accelerating towards the barycentre of the system, and if the orbit is circular, then they never get any closer to it, and the magnitude of the acceleration is constant (if the orbits are elliptical then they do approach & recede from it, and the magnitude of the acceleration varies over time).
The Earth's acceleration is towards the moon (ignoring forces from other things such as the sun). This is because the force of gravity between them is in the same direction of the geometric line connecting them, and according to Newton's second law the acceleration due to a force is in the same direction as that force. Just considering an Earth-Moon system, they both orbit about the center of mass of the system. So both bodies would be undergoing acceleration, where the acceleration of one body is towards the other.
I'm unsure what you mean about accumulation of acceleration. Forces determine acceleration. Acceleration isn't something that accumulates over time. It's just a result of the current net force acting on an object.
- 59,060
The acceleration of the Moon due to the force of the Earth is perpendicular to the velocity of the Moon. That's why the path of the moon is a circle. The same is true concerning the acceleration of the Earth due to the force of the Moon. The acceleration of the Earth is perpendicular to its velocity. Hence it does not "accumulate"; the Earth follows a circular path, as does the Moon.
In fact, the Moon does not orbit the Earth. It orbits the common center of mass of the Earth-Moon system. The same is true of the Earth; it orbits the common center of mass. However, the center of mass of the system lies inside the Earth, so the radius of the Earth's orbit is much smaller than the radius of the Moon's orbit, and is ignored for many purposes. It is detectable, and must be taken into account when doing precise astronomical calculations.
While it is true that the orbits are actually elliptical, that fact has no bearing whatsoever on the question of whether or not acceleration accumulates.
- 22,633
Why doesn't the Earth's acceleration towards the Moon accumulate to push the Earth off its orbit?
Because the Earth doesn't orbit the sun, the center of mass of the Earth-Moon system does. Earth and Moon in turn orbit this center of mass.
Orbits are a consequence of motion, which is aptly measured by kinetic energy. In order to change an orbit, kinetic energy must be expended in order to slow down, speed up, or redirect the orbiting entity. The orbiting of Earth and Moon is largely conservative, and does not produce nor consume energy, so they cannot alter their orbit.
No. When you accelerate in your car, you apply acceleration. When you brake, you apply more acceleration (you can prove this by having your friend sit in the car with an accelerometer). The result is not that your car goes really fast, the result is that your car is stationary. Direction of acceleration also matters.
For orbiting bodies, the acceleration is such that it is always orthogonal to velocity, so it only changes the direction of movement, never its speed. It also happens to be quite predictable, so the directional change results in the orbiter going in a circle.
The acceleration imparted on the Earth by the Moon will not make it collide, because the direction of the acceleration is always towards the Moon. Earth already has a large velocity orthogonal to that direction (ie. it is flying "past" the Moon) so the acceleration can only curve its trajectory in a circle.
Generally, you can think of orbits as falling towards an object, but constantly missing.
- 247
The moon is actually moving away from the Earth; 4 billion years ago it was much closer.
The moon raises tides which have the effect of slowing down the rotation of the Earth, so that the daylength is now much longer than it used to be, but some of the energy which has been lost by the Earth was captured by the moon, and it has boosted it into a higher orbit. It is still receding from us at the rate of a few centimetres per year.
- 2,348
- 1,748
