My exercise for a quantum optics course tells me to "find a normal ordering" for an Operator $\hat{O}(\hat{a},\hat{a}^\dagger)$, which is given as a (rather complicated) string of $\hat{a}$'s and $\hat{a}^\dagger$'s in random order.
To me, it is not clear, whether the tasks wants me to apply the normal ordering operator $:\ :$, which acting on an operator simply pulls all daggers to the right while neglecting the commutator rule or whether to use the proper commutation to create a normally ordered expression.
But that is not directly the question. When I open a textbook or my lecture note, when it is time to introduce the $P$, $Q$ and $W$ functions, they normally start by looking at some operator $\hat{O}$, then defining $:\hat{O}: = \hat{O}^{(N)}$. For example $:\hat{n}^2:= \left(\hat{a}^\dagger\right)^2\hat{a}^2$. Then an expectation value is calculated: $$\left\langle:\hat{n}^2:\right\rangle = \int d^2\alpha\ P(\alpha)\left|\alpha\right|^4$$
My problem is, that I don't see why one would use the normal ordering operator, because clearly the normally ordered operator is different from the unordered operator and will have a different expectation value.
And to extend that question: Can I calculate the expectation value for any normally ordered operator using the $P$ function? If I wanted the expectation value for $\hat{n}^2$ instead of $\left\langle:\hat{n}^2:\right\rangle$, would I have to bring the operator into normal order using the commutator relation?
