I am having troubles in understanding how to correctly perform the continuum limit of a double sum containing a Kronecker delta.
Imagine to integrate a function depending on $t$ and $t'$, both ranging from $0$ (initial time) to $T$ (final time):
$$I:=\int_0^Tdt_1\int_0^Tdt_2 f(t_1,t_2).\tag{1}$$
The corresponding Riemann sums, dividing the time intervals in slices of width $\epsilon=T/N$ is:
$$I_{disc}:=\sum_{j,j'=1}^N \epsilon^2 f(j\epsilon,j'\epsilon).\tag{2}$$
Obviosly lim$_{N\rightarrow\infty}I_{disc}=I$. Now consider the case when only the diagonal elements of the double integral are different from zero i.e.
$$J_{disc}:=\sum_{j,j'=1}^N \delta_{j,j'}\epsilon^2 f(j\epsilon,j'\epsilon).\tag{3}$$
I would expect that, in the continuum limit $N\rightarrow \infty$ ($\epsilon\rightarrow 0$) it becomes
$$J:=\int_0^Tdt\int_0^Tdt'\delta(t-t') f(t,t'),\tag{4}$$
where $\delta(t-t')$ is a Dirac delta.
Here is the problem: the Kronecker delta is adimensional, while the Dirac Delta has the dimensions of seconds$^{-1}$. This implies that $J_{disc}$ and $J$ have different dimensions, which does not make any sense. Therefore, there must be some mistake I am doing in going from the discrete to the continuum version of $J$. Could you help me spotting it and, more important, suggest the way to do this limit correctly?
Sandro
  • 31
The translation between the Kronecker delta function and the Dirac delta distribution is
$$ \frac{1}{\epsilon}\delta_{j,j^{\prime}}\qquad\longrightarrow\qquad\delta(t-t^{\prime}),\tag{A}$$
where $\epsilon$ is the "volume" of a unit-cell in the discretization. See e.g. this related Phys.SE post.
In particular, the rhs. of OP's eq. (3) should be divided with $\epsilon$ to have a finite continuum limit.
