I have a question about the definition of energy. the definition is "ability to do work". what does it mean? what is the ability that the definition talks about? what is the meaning of ability in energy? I understood the concept of work, and it would be great if someone could explain to me the concept and definition of energy.
My favourite example of using the definition: Why do we say that a body of mass m moving at speed u has kinetic energy of $\tfrac12 m u^2$ ? Imagine this: a cart of mass m moving at speed $u$ on level ground has a rope trailing from it. Someone grabs hold of the rope and exerts a constant retarding force -F on the cart, bringing it to rest in a distance s, while being pulled a distance s himself/herself. The cart's acceleration is $-F/m.$ So using $v^2=u^2+2as,$ we have $$0=u^2+2\frac{(-F)}{m}s.$$ So$$Fs=\tfrac12 m u^2.$$ But the cart exerts a force $F$ on the person via the rope, so does work $Fs.$ The cart's ability to do work was $\tfrac 12 m u^2,$ because that is the amount of work it could do!
- 37,325
Roughly speaking, work is the transfer of energy from one thing to another due to the application of a force through a distance in the direction of the force. In order for something to be able to transfer energy to something else, it must possess, at minimum, the amount of energy transferred for conservation of energy.
Thus something that possesses energy is capable of doing work.
In response to your follow up question:
but what ability means?
Ability (or capability, or capacity) means, in this context, the potential for doing work, that is, the potential for transferring energy to something else by means of force acting through distance. In order for something to have this potential, it must possess energy. Therefore, the possession of energy means having the ability to do work.
Hope this helps.
- 81,786
Energy is like a reservoir, which has been loaded with some flow of force say filled like a pond with work. It could give back that reserved work, in analogy with the pond some or all of its water.
But how much of it you can actually tap into has to do with many factors.
Again in analogy to the pond, you have to be at a lower level and also have enough room for all the water or energy.
Earthquake releases much energy, but a cardboard box can hardly take any of it, while a massive high-rise takes a lot.
Huge water reservoir behind a dam has much potential energy but if you want to tap it into a turbine you need to let some of it waste as the flow kinetic energy through the turbine.
So energy is capable of doing some work, but it needs means to deliver that work.
- 1,655
