Assuming we have 3 objects d,e,f moving on the same line while e is stationary, d is moving to the left at 'almost speed of light' and f is moving to the right at 'almost speed of light'. What is the speed at which f is moving from the perspective of d?
If its 0.9999999% speed of light, what does it say about their course? To my understanding, the perspectives of d,e and f are as followed:
  • from the perspective of d, e and f are both moving away at the sub speed of light
  • from the perspective of e, d and f are both moving away at the sub speed of light
  • from the perspective of f, e and d are both moving away at the sub speed of light
In order to keep all 3 statements true, all 3 objects (d, e and f) are supposed to be moving away from each other at a speed close to speed of light, so they should be virtually located on the vertices of an "invisible" equally-edged expanding triangle.
So my question is - what happened to the original straight line d,e and f were placed on during the acceleration of d and f to 'almost speed of light'?
To avoid a proliferation of nines, let’s take the leftward velocity of D, and the rightward velocity of F, relative to E to be 0.9 $c$. Then, using relativitic addition of velocities as explained here, we find that D sees F move rightward at
$$\frac{0.9+0.9}{1+0.9\times 0.9}c = 0.9945 c.$$
Similarly F sees D move leftward at this same speed.
There is no triangle, just straight-line relative motion with various relative velocities which are all sub-luminal.
G. Smith
  • 52,489
