It is said that photons, moving at c, do not experience time. But then, if a photon doesn't experience time, how can it have a frequency?
uKER
  • 173
We experience its frequency. It is projection to ascribe this experience to the photon itself.
For example, a corkscrew does not have a frequency. Yet when you look in a fixed direction to it passing by you experience a frequency.
my2cts
  • 27,443
This is quite an misleading sentence. It blindly translates the limiting case of the time contraction in the (hypothetical) case of a frame moving at the speed of light. However, such a frame does not and cannot exist. While particles moving at the speed of light do. In such a case, they move at speed $c$ in every inertial frame. In all these frames it is possible to speak about their frequency.
Actually, taking into account QM, the frequency of a monochromatic photon would be just a different name for its energy (through the relation $E=\hbar \omega$). For a real frequency, directly measurable through a measurement of time, one has to go to some coherent state of many photons i.e. to a real electromagnetic wave.
According to the second postulate of special relativity, photons are observed as moving at c, that means that the light ray propagating at c is mere observation.
The spacetime interval between the place of emission A and the place of absorption B of photons in vacuum is zero, that means that A and B are adjacent. This is sometimes interpreted as that photons do not experience time, but it might be more correct to say that there is nothing between A and B, the transmission of the momentum is happening directly from the mass particle A to the mass particle B, without need for any photon, and accordingly, the momentum and the frequency are transmitted directly from the mass particle A to the mass particle B, without need for a photon.
However, spacetime intervals cannot be observed by observers. That means, if a spacetime interval of a light ray moving from Sun to Earth is zero, observers will observe a space interval of 8 light minutes and a time interval of 8 minutes, this interval is filled by a light ray as a sort of "placeholder", and all observers will agree on the velocity c of the light ray.
Moonraker
  • 3,173
You need to be careful to which frames of reference your two statements "this photon has frequency $f$" and "a photon doesn't experience time" apply.
When you say "this photon has frequency $f = 5 \cdot 10^{14} \text{Hz}$",
then you actually mean "in my frame of reference (where my town is at rest) this photon has frequency $f = 5 \cdot 10^{14} \text{Hz}$."
Now transform, for example, to a frame of reference moving with speed $v = 0.999999\cdot c$ relative to your town. Then you have $\gamma = \frac{1}{\sqrt{1-v^2/c^2}} = 700$. In this frame the photon has the much lower frequency $f' = \frac{f}{\gamma} = 7 \cdot 10^{11} \text{Hz}$.
In the limiting case of a frame moving with speed $v = c$ relative to your town you have $\gamma = \infty$. (As pointed out in @GiorgioP's answer, this frame cannot exist. But let me be sloppy now.) In this frame the photon has the frequeny $f' = \frac{f}{\gamma} = 0$. So, only in this frame you can say, "the photon doesn't experience time".
