The dielectric medium gets polarized by say two randomly shaped charged bodies placed some distance apart.How does the resultant fields from dielectric diminish the coulomb force .There are a bunch of questions which follow up which I think won't be too much for this question.
Will there be a difference if the slab is placed at different locations along the line joining..if not , why ?
given that thickness of slab is constant only the surface is being enlarged , will it affect the force?
I am unable to understand the mechanism of this force reduction by dielectric, I have just found " field from dielectric reduces force " or some solved questions which convert the dielectric into vacuum of equivalent length to solve problems , no satisfying explanation yet. Please explain me the mechanism , gauss law and relevant things are known to me in case.
Asked
Active
Viewed 112 times
Aditya Prakash
- 1,123
Consider the simple case, A capacitor with dielectric placed between it. The negative plate of the capacitor polarize the dielectric end near to it and make it positive. Similarly the positive plate polarize the dielectric end near to it, negative. If the field due to the capacitor plates is in positive direction, then the field due to dielectric will be in the negative direction. Adding these two fields we will get a electric field less than the field due to the capacitor plate alone. Thus force $(F=qE)$ get reduced when dielectric is inserted. Approach this method to answer your questions.
walber97
- 1,428
