It is known that the specific heat of a gas is process dependent.So it must be theoretically possible to have a negative value for a gas according to the following equation (for polytropic process): $$ C = \frac R{\gamma-1} + \frac R{1-n} $$ where $C$ is molar specific heat and $\gamma$ is adiabatic exponent.
(supposing $\gamma = \frac{5}{3}$ and $n = \frac{4}{3}$, $C$ comes out to be negative)
Is it practically possible and if so what would it signify? As you provide more heat to a gas in such a process, would it lose temperature? Please clarify.
I don’t know where that formula comes from, but to the best of my knowledge (this is not to say I’m right) $C$ is a nonnegative quantity. Some extravagant cases do exist where it comes out to be negative indeed, but it is normally (again, to the best of my knowledge) a consequence of not properly considering one or several energy sources.
In the OP's equation, $C$ will be negative if $\gamma > 1$ and $1 < n < \gamma$.
That implies a system where mechanical work and heat are flowing in opposite directions. That is physically possible, for example a mechanical compressor is doing work to compress the gas, but the high temperature gas is losing heat to the environment by conduction through the compressor structure.
You could imagine a situation where the gas is losing heat to the environment faster than you do mechanical work to it, in which case its temperature would decrease.
But I can't quite see what you are going to discover about the system from this bit of mathematics that you didn't know already.
alephzero
  • 10,279
Assuming ideal gas conditions, The above equation $$C = \frac R{\gamma-1} + \frac R{1-n}$$
You need to know two things:
  1. The first part of the sum that is $ \frac R{\gamma-1}$ refers to the heat required to change the temperature of the gas by $1$K When no work is done by the gas.(Isochoric condition)
  2. The second part of the sum $\frac R{1-n}$ refers to the work that is done by the gas.
    As you change the temperature, the pressure and volume also changes and so the gas does work.
Now your question, when you have such a process which renders the specific heat capacity negative, that process actually decreases the volume of the gas with increase in temperature
Here, look at this graph
Hence work done by the gas is negative and this results in the above sum (the C equation) to become negative.
In short:
Heating the gas would lead to contraction of the gas, and the work done by the gas will be negative and greater than the heat required to changed temperature of the gas in isochoric conditions. This makes the thermal capacity negative
