What happens to the event horizons of each black hole as the two identical non-rotating black holes collide head on?
At a point exactly between them, is the curvature zero (do the individual curvatures due to each black hole cancel out)?
Does it mean that when the holes begin to merge (event horizons touch) the event horizon of each black hole recedes away because the curvatures cancel out?
Does that mean I would then be able to peer inside a black hole? [tantamount to information now escaping from the original insides of the black holes]
PM 2Ring
  • 13,541
No. GR is a nonlinear theory, so curvatures don't add in any simple way. Even if they did, the behavior of the Riemann tensor under a parity transformation along one spatial axis is not just a sign flip.
There is no direct link between curvature at a point (which is a local property) and the question of whether that point is on the horizon (which is a global property).
