This is generic feature of systems with relativistic energy-momentum relations, meaning
$$E=\sqrt{p^{2}+m^{2}},$$
where time and space are rescaled to have the same units (i.e. $c=1$), and $m^{2}$ is any nonnegative constant. The phase and group velocities are
$$u_{ph}=\frac{E}{p},$$
from $E=\hbar\omega$ and $\vec{p}=\hbar\vec{k}$ for a wave $\psi\propto\exp\left(i\vec{k}\cdot\vec{r}-\omega t\right)$; and
$$u_{g}=\frac{\partial E}{\partial p}.$$
Setting these two speeds to be reciprocals (since the constant $c$ has been set to unity) gives a differential equation for the energy as a function of momentum, $E(p)$,
$$\frac{dE}{dp}=\frac{p}{E}.$$
This is a first-order differential equation, so it has a one-parameter family of solutions. (That is, the general solution will have one undetermined constant.) In fact, this is a very easy separable equation, and a direct integration shows that the general solution is $E=\sqrt{p^{2}+m^{2}}$, with $m^{2}$ as the arbitrary constant.
So any system with relativistic dispersion relations will have $u_{ph}u_{g}=1$ (in these units).
