I am wondering about what force really is after I have looked up wikipedia, where there is stated that $F=ma$ only holds to be true for a constant $m$. For inconstant mass force is:
$$F=\frac{dp}{dt}= \frac{d(m(t)v(t))}{dt} = \frac{dm(t)}{dt}v(t)+a(t)m(t)$$
I cannot imagine this, this breaks my understanding of force. As far as I know, in Newtons mechanics force describes how strong a mass accelerates. It is a variable of state. But if it is a variable of State, for any state in time $s_{T}$ the force should be defined as:
$$F=m(T)\cdot \frac{dv}{dt}$$
I really do not get, what the term: $\frac{dm(t)}{dt}\cdot v(t)$ means. I do not understand why suddenly force should be dependet of the amount of velocity. I hope someone can help me build a new understanding.
Edit: Wikipedia also says that my formula is just wrong, I do not fully understand the explanation given in "variable-mass"-system paragraph. Could you explain it more detailed?
$$\mathbf {F} +\mathbf {u} {\frac {\mathrm {d} m}{\mathrm {d} t}}=m{\mathrm {d} \mathbf {v} \over \mathrm {d} t}$$
I do not see why this holds to be true, or where this comes from. Makes no sense to me at all. Basically expelling mass should already be displayed by the force $F$ since newtons third law holds to be true.
Thanks
TVSuchty
  • 161
I think you're overlooking two commonly understood examples of systems in motion, with changing mass:
  1. Classical propulsion of a rocket:
The rocket spews out large amounts of burnt fuel. It relies on conservation of momentum but the rocket's mass drops during flight. See the rocket equation.
  1. The relativistic rocket:
Increase in mass due to Relativity.
Gert
  • 35,561
The full equation of second law is inconsistent under transformations. Consider the a frame where $$F=m\frac{dv}{dt} + v\frac{dm}{dt}$$ Now consider another frame moving with a constant velocity $v'$. In that frame one can write $$F=m\frac{d(v-v')}{dt}+(v-v')\frac{dm}{dt}$$ There will be an additional factor of $-v'\frac{dm}{dt}$ in the expression. This means that in two different inertial frames there are different physical laws, which is obviously wrong. To keep the equations consistent with this transformation we write the equation as $$ F + u_{rel}\frac{dm}{dt} = m\frac{dv}{dt}$$ Where $u_{rel}$ is the relative velocity of the mass that is being added or subtracted to the system with respect to the system. If net force on a system with variable mass is zero then the change in mass accelerates the system.
The most general example of variable mass systems are rockets. Rockets are constantly releasing fuel, which reduces its mass. Another example can be machines guns firing bullets (though the bullets are generally much lighter than the gun).
In one of your comments I read that
Yes, but this spewing should already be in a or F. Since molecules are exerting pressure.
That is right the spewing force is included in $F$ but the variable mass is not. Since the spewing is constant the force of spewing is acting on different masses at different times. At time $t$ the constant force $F$ is acting on a body of mass $M(t)$. At time $t+\Delta t$ the same force is acting on a body of mass $M(t+\Delta t)$. That is what's missing from the equation.
Derivation of Variable Mass Equation
Consider a mass $dm$ that is added to a body of mass $M$ and velocity $v$. Let the velocity of $dm$ be $v_m$. Since the mass is being added the collision will be completely inelastic. Hence both $dm$ and $M$ will move with the same velocity, say $v+dv$. Since there is no net external force on the whole system we can conserve momentum. $$v_m dm +Mv = (dm +M)(v+dv)$$ or $$v_m dm + Mv =v dm + dmdv + Mv +Mdv$$ The term $dmdv$ is very small and hence can be are to zero. The equation becomes $$-(v-v_m)dm = Mdv$$ Dividing by a small time interval in which impulse occurs $$-u_{rel} \frac{dm}{dt} = Ma$$ The minus is because $dv$ is negative, i.e $v<v+dv$ (the mass was decelerated). If there is a net force $F$ then $$F = \frac{v dm + dmdv + Mv +Mdv - v_m dm -Mv}{dt}$$ Or $$F-u_{rel} \frac{dm}{dt} =Ma$$ Which is the desired result.
Hope this helps.
First let me assume we are arguing on constant mass.
The mass, in Newtonian Mechanics, is a property of an object that tells us the resistance it exhibits to be accelerated. Force causes a change in object's motion, so the magnitude of such quantity can be understood as how much the motion of an object has changed. To sum up, I'd say 'force describes how much a mass has been accelerated' instead of 'force describes how strong a mass accelerates'.
I do not understand why suddenly force should be dependent on the amount of velocity.
Note that the force is not characterised by the velocity of the object but by the change of it. I always like to think of the Newton's First Law; note that an object can move at constant velocity in the absence of forces
How to understand force when the mass of an object changes
Think of the classic propulsion of a rocket. The spacecraft must lose mass in the form of gases to be accelerated. This change on mass means a change on rocket's momentum, that equals the force exerted by the gases on the rocket (which is also called thrust or impulse).
Actually, you can model a system rocket + gases whose momentum and mass are conserved.
JD_PM
  • 807
-2
Force is defined as $F=dp/dt$, where $p=mv$. Since both $m$ and $v$ are varying with time, you must use the product rule to arrive at a proper derivative. From calculus, the product rule is $d(uv)=udv + vdu$. Following this rule, and taking the derivative of both $m$ and $v$ with respect to time, you get:
$d(mv)/dt = mdv/dt + vdm/dt$
$dv/dt=a$, so the derivative simplifies to
$d(mv)/dt = ma+vdm/dt$
David White
  • 12,602
