14
In a dark room there are two people and a very faint candle. Then the candle emits one photon. Is it true that only one person can see the photon? Why? And are there any experiments?
Edit 2019/4/23:
Thanks a lot. I was originally asking about quantum mechanical things. Because I believe such an experiment will turn the two people into Schrodinger's Cat. That's weird because it is not likely for a macroscope object get correlated so easily. Now thanks to the answers I realized that the efficiency and noise is as bad as in cases of other quantum mechanical processes.
fangzhang mnm
  • 303
7 Answers7
38
Seeing = detecting photons that happen to interact with your retina.
You can't see photons when they are just travelling nearby. Take lasers for example. When someone is using laser pointer, the only reason you see the beam is that photons collide with dust and air particles and therefore their direction is changed. For example into your eye. Otherwise you wouldn't see anything.
It isn't possible for two people to see the same photon.
Andrej
  • 557
11
In theory, in the most perversely contrieved case, and if you are willing to cheat a bit, it would be possible. In any half-reasonable, realistic setting, the answer is a clear, definite "No". Indeed, people cannot even see single photons at all (contrary to urban myths).
How does seeing a photon work? The photon has to hit your eye, specifically one of the billion rhodopsin molecules in one of the several-million retinal cells, then something-something, and then a nerve impulse maybe, if some conditions hold goes through the roughly-one-million ganglion network in the retina, and maybe makes it to the brain. Maybe. And maybe the visual cortex makes something of it.
The "maybe" part and the fact that a single cell has billions of G-proteins going active and inactive every second, and that there's a continuous flow of cGMP up and down is the reason why you cannot really see a single photon. That just isn't reasonably possible, if anything it's placebo effect or mere suggestion.
So what's that something-something mentioned previously? The photon flips the cis-bond at position 11 in retinal to trans. Which, well, takes energy, and absorbs the photon. This triggers a typical G-protein cascade, with alpha subunit going off and blah blah, resulting in production of cGMP at the end. If the cGMP concentration goes above some threshold, and if the cell isn't currently refractive, then the cell fires an AP. That's a big "maybe". Then comes something-something ganglion cells, which is the other big "maybe" part above.
The photon is "gone" after that. No second person could possibly see it.
Now of course, no absorption is perfect, there's an absorption maximum for each type of rhodopsin, and even at that it isn't 100%. Outside the maximum, the absorption is far from 100%. Which means that the photon is emitted again, and it could, in theory, in the most improbable case, hit another person's eye, why not. But of course we have to cheat a bit here because it strictly isn't the same photon.
Unless we are willing to cheat, the answer must therefore be "not possible".
Damon
  • 373
Candles do not give off single photons. Preparing light sources that can emit single photons is tricky.
The photon contains "one photon" (some small quantity of electronvolts) of energy. The energy in a photon is directly propotional to its frequency, so two photons of the same "color" have the same energy. The process of absorbing a photon transduces "one photon" of energy from the electromagnetic field to the detector. Consequently, if either human detects the photon, there is no energy left to be detected by the other human.
In "Direct detection of a single photon by humans", J.N. Tinsley et al. directly measure the event of conscious detection of single photons. Subjects in that experiment
  • did (barely) better than chance (51.6% (p=0.0545)) correctly identifying photon present and photon absent events) when observer confidence in event was excluded and
  • did better than chance (60.0% (p=0.001)) when confidence was included.
Interestingly, "the probability of correctly reporting a single photon is highly enhanced by the presence of an earlier photon within ∼5 s time interval. Averaging across all trials that had a preceding detection within a 10-s time window, the probability of correct response was found to be 0.56±0.03 (P=0.02)."
Of course, not every photon that strikes the retina is transduced. "Based on the efficiency of the signal arm and the visual system, we estimate that in ∼6% of all post-selected events an actual light-induced signal was generated ..." So we expect to see improvements over random chance in the neighborhood of 6%, and all numbers reported above are in that neighborhood.
Eric Towers
  • 1,797
Two people cannot see the same photon. Only one person can see a specific photon.
To see a photon, it must be absorbed by a molecule in the retina [1]. The photon then no longer exists, so it is not available to be seen by another person.
[1] Mammalia retinas can respond to single photons
Somehow the exchange of energy between all objects must take place. It was found that this process takes place through the emission and absorption of photons (initially called energy quanta).
Photons are indivisible particles, they do not loose or gain inner energy during their life. The detection of a photon is possible only through the absorption of this photon.
Theoretically, it is possible to obtain information about an absorbed photon by observing secondary emitted photons with lower energy (and longer wavelength).
If you think of a laser beam that you have seen from the side, dust particles in the air are responsible. They reflect the laser light and you can see the beam. Of course, the photons reflected from the dust into the eyes do not arrive at the laser target.
HolgerFiedler
  • 10,980
Candles emit huge numbers of photons per second, and humans can't reliably detect single photons, so let's simplify your experiment to the bare essentials.
In the middle, we have an atom that we can excite (by firing a photon at it). Shortly after we excite this atom, it emits a single photon with a spherically symmetric radiation pattern, that is, there's an equal probability of detecting the photon in any direction. This is a standard example of an atom scattering a photon.
Now we place several identical photon detectors around our emitter atom, in various directions. After the photon is emitted, one of our detectors may detect it. Or the photon may miss all of our detectors and collide with something else.
We can model this as a spherical bubble centred on the emitter atom, expanding at the speed of light. When the bubble reaches a detector atom, that atom may detect the photon. When that happens, the bubble disappears, like a pin bursting a soap bubble. No other detector can detect the same photon (not even another detector at the exact same distance), all of the photon's energy was absorbed by the detector that was activated.
PM 2Ring
  • 13,541
-1
The question is in question here. Ultimately if you are looking for specific information from a specific photon without considering any other information or photons as reference, you are limiting your scope. It's like looking at a single 1 in binary code without any reference to the rest of the code. Consider your eye generates information about your photon and sends this report to your brain. Well we are getting second hand information. So now you have to consider does your friends eye report the same information about this photon that your eye would if your eye was in the same position at the time of the detection? In this situation we are excluding relative information like which receptor it landed on and if any other photons have been detected in the past or near by. Here is how you and your friend could both "see" that same information about this specific photon. If you were to split the signal containing this report generated from the detector in this case the eye, and sent one signal to your processor or brain and one to your friends, then you could share the same information simultaneously. How you interpreted this information is what makes you unique. Sorry, Why are we trying to share a photon? They are abundant aren't they?
