How can charged particle have constant kinetic energy in uniform magnetic field. I mean particle is accelerating so it must radiate EMW and loose energy?
Asked
Active
Viewed 366 times
A charged particle in a magnetic field only has constant kinetic energy only if radiative losses are ignored. Indeed, as you correctly pointed out, a particle will lose energy due to radiation as it is accelerated by the magnetic field. However, radiative effects are typically suppressed by several powers of $c$ (by the Larmor formula), so at nonrelativistic speeds, kinetic energy is very nearly constant.
