So I was on a plane and tiny crystals of ice formed on the window glass. This window is formed by a few screens of glass (maybe or maybe not) with vacuum inside. I think the frost was due to some water vapor in the outer vacuum chamber, since at times also some condensed vapor appeared.
So there is vapor with the cold glass wall: the vapor condenses; when the glass becomes too cold the vapor freezes; then at a point sun shines on the glass and some condensation begins to appear (I'd say through sublimation of the frost).
Now the question is explaining the following: this newly obtained vapor condenses again on the glass wall (which still has some frozen crystals), but it condenses only at a certain distance from the frozen crystals. The pattern of the condensation encircles the ice crystals, which are surrounded by a region with no condensed vapor.
I have two hypotheses/ideas:
a) the region surrounding the crystal has no vapor because there the probability of being caught by the ice is higher than that of being caught by the glass: the ice is still very cold (maybe it can be lower than zero since it is sublimating and not melting) while the glass is now above zero (the vapor condenses on it in liquid droplets);
b) the glass surrounding the ice crystals is hotter because it receives heat from the crystals, which receive heat from the sunrays..
There could be other possibilities like:
vapor released from the crystal has high kinetic energy and therefore has a mean free path (like 1 mm of half mm) before being caught by the cold glass wall;
or the glass nearby the ice is colder and for some reason this impedes condensation (maybe if it is below 0°C ? Bah this does not sound correct..)
The point a) is not very consistend with the fact that the ice is sublimating and with the fact that there is zero condensation in the near surrounding of the ice; the point b) could work if the sublimation has a low rate so that the ice loses its heat mainly by contact with the glass..
So does anyone has any other idea of why condensation does not happen nearby the ice?
AoZora
  • 1,924
  • 27
