Alice is in a rocket hovering outside a BH event horizon when her rocket runs out of fuel, and thus begins a free-fall decent. Bob is also in an inertial frame but at a very large distance.
It is commonly said that Bob will see:
a. Alice forever approaching the event horizon but never crossing it
b. Alice's clock tick ever more slowly
c. light emitted by Alice as becoming ever more red-shifted
My question: Is the observed time dilation due to relative velocity (i.e. reciprocal) or is it due to gravitational time dilation (non reciprocal)?
In other words: Does Alice see Bob aging quickly (non reciprocal dilation) or does she see Bob aging less than herself (reciprocal dilation)?
Edit: Yes, Schwarzschild geometry. Alice and Bob are radial. Mass of BH and Alice's initial distance from the horizon are unspecified (free parameters) which will impact the evolution of the time dilation of Bob from Alice's frame.
Doppler shifts (red/blue) are the same effect as changes in the time intervals between signals and changes in the rate at which one person sees the other aging.
You don't say whether Bob and Alice are along the same radial line, which can make a difference. Let's say they are.
Alice is initially at rest, so she sees Bob's signals as blueshifted due to gravitational time dilation. As time goes on and she accelerates, she will see this change to a redshift. (The case where she starts fairly far away from the black hole is particularly simple. In that situation, the Doppler shift is $1/(1+r^{-1/2})$, where $r$ is her radial coordinate in units of the Schwarzschild radius.
It is a misconception that relative velocity will itself cause time dilation. Black holes do have stress-energy and the difference between the stress-energy (strong effect) at the event horizon and far away from it (lesser effect), will cause the time dilation. This is what you call gravitational time dilation.
Because of the equivalence principle, acceleration (which is absolute in the universe) will have the same effects as the gravitational zone. So yes, acceleration will (can) cause time dilation. But in your case, if the movements of Alice and Bob are constant speed, that fact itself will not cause time dilation.
Now in your c. you say that light emitted will be seen more red-shifted. That is actually not true always. It depends on the actual position of Alice and Bob and their relative motion. Sometimes it will acutally be blueshift. Please see here:
Communication near a black hole
You are asking about the aging, and if you only take the gravitational stress-energy difference into account (and disregard their position and motion) then Alice will see Bob age quickly. If you consider their position and motion, then the answer is again depending on the situation.
The time dilation of Alice in Bob's frame is
$$ \rm \frac{d t}{d \tau} = 1 \div \sqrt{1-r_s/r} \ \div \sqrt{1-v^2/c^2}$$
while the time dilation of Bob in Alice's frame is
$$ \rm \frac{d \tau}{d t} = \sqrt{1-r_s/r} \ \div \sqrt{1-v^2/c^2}$$
where t is the time elapsed on Bob's clock, τ on Alice's and v the local velocity of Alice relative to a stationary probe. Bob is far away from the black hole in this scenario. The gravitative component of the time dilation is absolute, while the kinematic component is relative, see here.
Here we are assuming Schwarzschild geometry, in the vicinity of rotating or charged black holes the split of the components is little bit more complicated but following the same principle.
So if Alice would be free falling from infinity (then v would be the negative escape velocity) both components would cancel in her frame, and Bob would age with the same rate as herself. In Bob's frame Alice then would age with the squared rate of locally stationary observers at the same height above the black hole.
If you are not only asking about the time dilation but also what one sees with his eyes, you also have to take the regular Doppler shift into account, which makes the received signals redder when they move away from each other, and bluer if they move towards each other. Which effect is the strongest depends not only on her exact position but also on her velocity and vector relative to Bob.
For example, if Alice falls from rest position at r=5rs, and Bob stays fixed at this position, Alice reaches the horizon after a proper time of τ=33.7GM/c³. If she watches Bob, the time she sees on his clock in the moment when she crosses the horizon would be t=27.328GM/c³, so Bob's signal would visually appear redshifted in her frame.
Since her free fall velocity is smaller than the escape velocity (because she fell from rest at finite height) Bob's clock would still be ticking faster in her frame though, but in this scenario the effect of the regular Doppler shift would trump the time dilation visually.
Yukterez
  • 14,655
