The equation $$V_{rel} \frac{dm}{dt} - mg = ma $$
  1. what is the meaning of m in the given equation is it the mass of the rocket and the point with which we are concerned or is it the initial given mass?
  2. why is there a need of V relative in the formula?
Atharv
  • 39
You might notice that Newton's second law has a form that rate of change of momentum of a system is what external force is as we might assert that internal forced to an system of particles can't change the momentum of the system now as we can se that by simple product rule we have the following result derived. Now for the significance of V and m let's start by saying m as the mass of rocket as a function of time as we can notice that as rocket propels up in the space it uses the thrust due to released gases. Now let's look at momentum of system it can be written as $(M-\Delta m) v_1 + (\Delta m) (-v_2) = 0$ which would imply that $M = \Delta m ( v_1 + v_2)$ now from kinematics point of view the velocity term can be represented as $V_{\rm rel}$ and differentiating the same would yield what you need.
Aditya Garg
  • 701
  • 15
