A classic problem in determining the motion of a negative charge when displaced from a positively charged ring shows that the charge oscillates.
However, Earnshaw’s theorem states that (quoting Griffiths) ‘A charged particle cannot be held in stable equillibrium by electrostatic forces alone’. However, the system above seems to be stable. What causes this seemingly contradictory results?
Displacement along the symmetry axis results in a restoring force along the symmetry axis as you have calculated.
Now ask what happens if it is displaced radially?
Answer: the charge is unstable to radial displacements.
The theorem is proved in 3D space, so a problem confined to a single dimension is not subject to it. If you take the same geometry and consider it in 3D the theorem holds.
Classically, introducing extended objects such as a ring also introduces additional forces: The ring is held together by elastic forces working against the positive charge distribution which pushes against itself. Without it, the ring will expand indefinitely.
On the other hand, I am not sure if the statement holds quantum-mechanically, as one may argue that all "contact" forces are electromagnetic in nature.
A negative charge in the centre of a positively charged ring is in a metastable state, so not stable Any deviation form this perfect geometry will lead to collapse. The theorem applies.
my2cts
  • 27,443
