-2
I need to know the exact meaning of potential energy. I AM confused what it actually means.They say all types of energy comes under 2 types kinetic and potential so what is potential energy then?
My question ask for defination
The main point about energy is that it is a single-number property (in technical language, a scalar rather than a vector) that is conserved overall in any isolated system.
I will distinguish between kinetic energy, internal energy and potential energy.
Kinetic energy is a property that can be directly attributed to or associated with a single body, and is connected to its motion. It is, though, a relative property, in that its value will depend on what frame of reference has been adopted.
Internal energy is energy stored inside a body. It could for example be stored in the form of elastic energy inside a spring, which ultimately comes from a combination of molecular vibrations and field energy in the electromagnetic fields between the molecules. One can include relativistic rest mass energy as a form of internal energy.
Potential energy is not a property of any single body in quite the same way as either kinetic or internal energy. It is rather a way of keeping track of interaction energies, and usually it quantifies the amount of energy that is in fact located in a field. For example, when two like charges are pushed close to one another, the energy provided by the forces that pushed them together is stored in their joint electromagnetic field. It is called field energy, which is the form that internal energy takes when it is stored in a field such as electric field. Similarly, when we lift an object, the energy we provide is stored in the gravitational field. What happens is that when the object is lifted up, the size of the joint gravitational field of that object and the Earth together is very slightly increased in some regions and decreased in others, with a net result that the integral over volume of the square of the field strength has gone up.
At the fundamental level, then, we can say that we don't need to consider potential energy at all, as long as we include kinetic energy and field energy. Sometimes people will call field energy by the name potential energy, which I guess is ok as long as they know what they are doing. Internal energy is the sum of all the kinetic energy and rest mass energy and field energy of the parts of a body.
In the case of gravity there are further subtleties that come in when one considers general relativity, but in ordinary conditions (the weak field limit) you do not need to worry about that.
Andrew Steane
  • 65,285
You may understand potential energy in classical mechanics as stored work, where work is defined as $$ W = \int_{\cal C} \vec{F}\cdot d\vec{s}.$$ Here, the force $\vec{F}$ is to be understood as a conservative force, in contrast to a dissipative force (such as a frictional force) acting on a body. The force acts along curve ${\cal C}$.
A conservative force is one for which the value of the above integral depends only on the endpoints of the curve $\cal C$, but not on its shape in-between.
In this sense, also kinetic energy can be understood as a form of stored work (acceleration work), but we have the special term kinetic energy for it.
flaudemus
  • 2,239
