What is the meaning of $d$? Is is Delta? If it is Delta, why is it then not $\Delta$? I am still confused with that. Can someone help explain it to me?
While it's more on the mathematical side, this Wikipedia article should answer your question in more detail (or also here
For physicist, $d/dt$ is the time derivative of a quantity, $\vec{p}$ in your case. So what your formula says is that "force $\vec{F}$ is the time derivative (the change over time) of momentum $\vec{p}$".
This is somewhat related to Delta ($\Delta$). For linear functions, one can calculate the slope $s$ via "rise over run", $$ s = \frac{\Delta y}{\Delta x} $$ If your function is not linear, you can still approximate the slope for a short section with this. To get more accurate results, you can shorten your Delta. In the limit of $\Delta \to 0$, you get the differential mentioned in the Wiki article. Mathematically, the slope at point $x_0$ is then also called the derivative of $f$ at $x_0$ $$ s = f'(x_0) = \lim_{\Delta x \to 0} \frac{f(x_0+\Delta x) - f(x_0)}{\Delta x} $$ So, the force $\vec{F}$ is the time derivative of your momentum $\vec{p}$, $$ \vec{F}=\frac{d \vec{p}}{dt} = \frac{d}{dt} \vec{p} $$ EDIT: so, what the answer to the question "what is the meaning of $d$?" should probably be is: if you make your $\Delta$ really, really small (infinitesimally small, to be precise), you get $d$.
