Suppose we take the spacetime point of your conception as the origin, $(t=0, x=0)$, then the spacetime point for your birth would be $(t=T, x=uT)$. The time $T$ is approximately $9$ months, and we are writing the spatial position of your birth as $x=uT$ where $u$ is a velocity. The velocity $u$ can be any value from zero (i.e. born in the same spot as conception) up to $c$ (because your mother can't move faster than light).
Now we'll use the Lorentz transformations to find out how these events appear for an observer moving at a speed $v$ relative to you. The transformations are:
$$ t' = \gamma \left( t - \frac{vx}{c^2} \right ) $$
$$ x' = \gamma \left( x - vt \right) $$
though actually we'll only be using the first equation as we're only interested in the time. Putting $(0,0)$ into the equation for $t'$ gives us $t'=0$ so the clocks of the observer and your mother both read zero at the moment of your conception. Now feeding the position of your birth $(T,uT)$ into the equation for $t'$ we get:
$$ t' = \gamma \left( T - \frac{vuT}{c^2} \right ) $$
For you to be born before you were conceived we need $t'\lt 0$ and that gives us:
$$ T \lt \frac{vuT}{c^2} $$
or:
$$ vu \gt c^2 $$
We know that the observer's velocity $v$ cannot be greater than $c$, and your mother's velocity $u$ cannot be greater than $c$, so this inequality can never be satisfied. That is, there is no frame in which you were born before you were conceived.
The rule is that two events that are timelike separated, i.e. their separation in space is less than their separation in time times $c$, can never change order. All observers will agree on which event was first. For the order to change the events have to be spacelike separated. In this case this would mean $uT \gt cT$ i.e. your mother would have to have moved at a speed $u$ faster than light between your conception and birth.
