In 'Non-abelian Bosonization in Two Dimensions', Witten shows that the Poisson brackets of the currents that generate the $G\times G$ symmetry of the WZW model give rise to a Kac-Moody algebra upon canonical quantization.
The Poisson brackets are calculated on page 465 to be \begin{equation} \begin{aligned} \left[X,Y\right]_{PB}&=-\frac{\hbar}{2}\delta'(\sigma-\sigma')\textrm{Tr}~g^{-1}(\sigma)Ag(\sigma)g^{-1}(\sigma')Bg(\sigma') \\&=-\frac{\hbar}{2}\delta(\sigma-\sigma')\textrm{Tr}\bigg([A,B]\frac{\partial g}{\partial\sigma}g^{-1}\bigg)-\frac{\hbar}{2}\delta'(\sigma-\sigma')\textrm{Tr}~AB. \end{aligned}\tag{29} \end{equation} for $X=\textrm{Tr} A \frac{\partial g}{\partial \sigma}g^{-1}(\sigma)$ and $Y=\textrm{Tr} B \frac{\partial g}{\partial \sigma'}g^{-1}(\sigma')$, where $g$ is a map $g:\mathbb{R}\rightarrow G$, and where $A$ and $B$ are arbitrary generators of $G$.
My question is, how does one go from the first line to the second line?
In my attempts so far, I am unable to obtain the second term of the second line. To be precise, starting from the first line above, writing $\delta'(\sigma-\sigma')$ as $\frac{\partial}{\partial \sigma}\delta(\sigma-\sigma')$, and using partial differentiation (and dropping the boundary term), one arrives at \begin{equation} \begin{aligned} \left[X,Y\right]_{PB}=&-\frac{\hbar}{2}\delta(\sigma-\sigma')\textrm{Tr}~g^{-1}(\sigma)\frac{\partial g}{\partial\sigma}(\sigma)g^{-1}(\sigma)Ag(\sigma)g^{-1}(\sigma')Bg(\sigma')\\&+\frac{\hbar}{2}\delta(\sigma-\sigma')\textrm{Tr}~g^{-1}(\sigma)A\frac{\partial g}{\partial\sigma}(\sigma)g^{-1}(\sigma')Bg(\sigma')\\=&-\frac{\hbar}{2}\delta(\sigma-\sigma')\textrm{Tr}\bigg([A,B]\frac{\partial g}{\partial\sigma}(\sigma)g^{-1}(\sigma)\bigg), \end{aligned} \end{equation} which is only the first term of the expression we want. It seems like allowing $A$ and $B$ to have dependence on $\sigma$ may give us the remaining term, but this is not correct, as Witten states explicitly that $A$ and $B$ are matrices on page 462.
Mtheorist
  • 1,211
I think he may be using the distributional identity $$ f(x)\delta'(x-a)=f(a)\delta'(x-a) -f'(a)\delta(x-a) $$ which comes from differentiating $$ f(x)\delta(x-a)=f(a)\delta(x-a) $$ with respect to $x$.
mike stone
  • 58,971
  • 53
  • 158
When you did the integration by parts you neglect the fact that this expression should be thought as being integrated together with a test function $f(\sigma)$ (or a test function $f(\sigma')$), so you need to be careful about throwing away the total derivatives since this derivatives will act on the test function as well.
Suppose you have the distribution $\delta'(x)g(x)$, then acting with a test function gives
$$ \int dx\,\delta'(x)g(x)f(x) = - \int dx\,\delta(x)(g(x)f(x))'= - \int dx\,\delta(x)(g'(x)f(x)+g(x)f'(x)) $$
so you have $\delta'(x)g(x)\rightarrow -\delta(x)g'(x)-\delta(x)g(x)\frac{d}{dx}$. The distribution that does this is
$$ -\delta(x)g'(0)+\delta'(x)g(0) $$
as you may check by applying a test function on it.
Nogueira
  • 5,892
