Imagine a wire with current I flowing through it. If we take a closed loop that doesnt contain the I the line integral will be zero. Does this means magnetic field is zero ? Also does Ampere law calculating the total magnetic field or only the sum of magnetic fields from the currents that are enclosed in the loop?
Asked
Active
Viewed 1,406 times
of course not. Unless you can argue that the magnetic field is constant over the loop so that $\oint \vec B\cdot d\vec \ell= \vert\vec B \vert \oint d\ell$ you cannot deduce anything about $\vec B$.
In the same way if a Gaussian surface encloses no charge it does not mean the field is 0 unless the magnitude of $\vec E$ is constant over the surface.
ZeroTheHero
- 49,168
- 21
- 71
- 148
