Specifically I'm referring to the equation below which I took from wikipedia.
The derivation of this equation based on the Drude model seems to somewhat standard as all the resources I've looked at do it the same way: Consider the momentum an infinitesimal time (dt) after some collision at t. This would result in an equation with differentials (differentials as in dt not dp/dt for example) and after some algebraic manipulation with these differentials and application of probability theory, they would finish by neglecting a differential of small order and taking a limit from which the above equation would arise. Now I understand heuristically why these derivations are reasonable, however, I do not understand the underlying mathematics behind the differentials and the neglect of a differential term of low order. As such I am hoping someone could
a) Provide a derivation of the equation based on the Drude model with more mathematical rigour (No differentials like dt on their own only full derivatives or in integrals, and have everything well defined mathematically)
b) Provide a reference for a)
I should note, the derivation does not need to be simple, nor do I need every little bit explained, so long that everything is defined precisely I am confident that I will be able to understand it.
Thanks!
http://www.physics.iisc.ernet.in/~aveek_bid/PH208/Lecture%201%20Drude%20model.pdf
If you are not familiar with the standard derivation I am referring to, here is a link
