45
My girlfriend and I were watching Cosmos, and something Carl Sagan said got us wondering what the farthest-away visible star is. Obviously "visible to the naked eye" is a fuzzy concept that might have many defensible answers, but hopefully not too many.
To make the question a little more interesting, let's restrict to individually distinguishable stars; otherwise the answer is pretty clearly some Local Group galaxy, and there aren't many of them to check.
The closest thing to a reasonable answer we came up with was this wikipedia list of stars that are more luminous than any closer star. The farthest-away star on that list with a plausibly visible apparent magnitude is Eta Carinae (7500 ly away, magnitude 4.55). However, there are several reasons why I'm not willing to consider this definitively answered:
  • It's a wikipedia article, and a poorly sourced one at that. So I don't entirely trust it.
  • It sorts stars by bolometric luminosity rather than visual luminosity, so perhaps there's some farther-away star whose spectrum is better-centered in the visible range.
  • The farthest-away visible star isn't actually guaranteed to be on a list of that sort, even assuming the other two points are cleared up. Perhaps the farthest-away visible star is only barely visible, and there's some star both closer and absolutely brighter than it which makes the list.
Given all these points, is it actually the case that Eta Carinae is the farthest-away visible star, or is there some visible star that's farther from us?
Micah
  • 588
5 Answers5
27
Following the questions raised by Rob Jeffries, I have completely rewritten my answer:
What is the farthest-away star visible to the naked eye?
Indeed, this question has many defensible answers. It is not just the concept "visible to the naked eye" that is fuzzy. The stars we see are seldom single objects, but rather binary and multiple star systems. Do we allow doubles and multiples? The wording of your question ("let's restrict to individually distinguishable stars") suggests to exclude multiple star systems. But the candidate farthest visible star put forward (Eta Carinae) is exactly that: a multiple. And like most highly luminous stars Eta Carinae is also a variable star. Should variable stars be allowed? Should we allow variable stars that in the recent past were visible to the human aye, but currently are not? If so, do we also allow cataclysmic variable stars? Do we allow novae and supernovae? Apart from all these ambiguities, as stressed by Rob Jeffries in below comments, there is also the issue of (often considerable) uncertainty in cosmic distances. How do we handle these uncertainties?
Let's first define what we mean by "visible to the naked eye". Which stars are visible to your naked eye depends on the light pollution of the site you are observing from and the atmospheric conditions (and obviously also on you eyesight). A so-called "magnitude 6 sky" is often taken as the standard for a good dark site with no light pollution. The threshold stars you can see in such a night sky have apparent magnitude 6.
So we can eliminate a key ambiguity by changing the question into "which star brighter than 6th magnitude is farthest away?".
According to this article :
"The farthest star we can see with our naked eye is V762 Cas in Cassiopeia at 16,308 light-years away. Its brightness is magnitude 5.8 or just above the 6th magnitude limit."
This answer puts forward a variable star, but clearly excludes supernovae as that would have resulted in much larger distances (more about that later). Rob questions the apparent five-digit accuracy in this answer. A bit of research reveals that the distance figure is derived from the central value in the measured parallax of 0.22 +/- 0.59 mas (milli-arcseconds). This means that we have no more than a 50% confidence that the distance is indeed 16 kly (kilo lightyear) or more.
We should not blindly accept a 50% confidence level. Rather, we should agree on a confidence level that is deemed sufficiently strict for the intended purpose of selecting the most distant star. Yet another ambiguity to resolve!
I propose to use the one standard deviation upper range of the parallax measurement (in the case of V762 Cas 0.22 + 0.59 = 0.81 mas) to derive distances. This gives us an estimated distance of 4.0 kly with a confidence of about 85% that the actual distance is at least this value. (As Rob points out, a more recent parallax measurement for V762 Cas results in 1.18 +/- 0.45 mas. If we would combine both parallax measurements to derive a chi-square estimate of the actual distance, we arrive at a value compatible with 4 kly.)
This results in the conclusion that the often quoted V762 Cas (see e.g. here and here) is unlikely the most distant naked-eye-visible star. For instance, HIP 107418, put forward by Rob as candidate most distance star, has a lower one standard deviation upper range of parallax of 0.62 mas, corresponding to a 85% confidence distance of 5.3 kly.
I do not have the means to analyze extensive star data bases, but offer this candidate most distant naked-eye-visible star: AH Sco, with a one standard deviation upper range of parallax of 0.48 mas, leading to a 85% confidence that its distance exceeds 6.8 kly.
Finally, what answer do we arrive at if we allow for a broader range of variable stars, including supernovae?
I propose SN 1885A at a distance of 2.6 million light years (!) as the most distant single star that was once (almost 130 years ago) visible to the naked eye.
Johannes
  • 19,343
14
I have taken the revised Hipparcos parallax catalogue, produced by van Leeuwen (2007, Astronomy & Astrophysics, 474, 653) and taken a subset of stars with Hpmag <6 (i.e. roughly the naked eye limit) and accepted only those objects with a parallax/error in parallax > 2.5. Anything with a larger fractional error in parallax really can't be trusted.
If I then look at this list, sorted by the reciprocal of parallax I see a number of candidates for the most distant naked eye star. I will list the top 4.
Name          Hpmag  |  Plx (mas)  |  e_Plx (mas) | Distance (pc) | Name/Spectral Type
HIP 107418    4.39      0.48           0.14         2080            nu Cep  A2 I
HIP 22783     4.29      0.52           0.19         1920            alpha Cam  09.5 I
HIP 54463     4.09      0.52           0.17         1920            chi Car  G0 I
HIP 107259    3.91      0.55           0.20         1820            mu Cep  M2 I
Note that V762 Cas (=HIP 5926) has a distance of only 850 pc (parallax 1.18 +/-0.45 mas) according to this catalogue. The oft-quoted Deneb has a parallax of 2.31 +/- 0.32 mas and thus is likely closer than 1000pc.
The top 4 are all blue supergiants or yellow/red hypergiants. The last one on the shortlist is a well known and very well studied object. The size of the error bars is such that it is hard to say which (exactly) is the most distant, and there are another few further down the list that could be more distant within their parallax uncertainties. The Gaia results in early 2017 will resolve this issue.
Eta Carina does not have a parallax in the Hipparcos catalogue, but this maybe because it was too faint at the time or more likely it is not a sufficiently point source (surrounded by nebulosity) for the data analysis to work properly. The SIMBAD CDS catalogue lists is as V=6.21 (from the Ducati [2002] photometry catalogue) and that is also its magnitude in the Yale Bright star catalogue. Of course, it is a variable and has been much brighter in the recent past, so was a naked eye object and it currently is a naked eye object. The system has a binary nature, though the secondary companion is of much lower mass and contributes only a small fraction of the light (Mehner et al. 2010, ApJ, 710, 729).
Allen & Hillier (1993, PASA, 10, 338) give a distance of 2200 +/- 200 pc using a so-called "expansion velocity" method. The star may be part of a larger association that includes the Tr 14 and 16 clusters that have a distance of 2900 +/- 300 pc (Hur et al. 2012, AJ, 143 41). So probably it is more distant than the 4 objects I listed above and is a current naked eye object (late 2014) with V$\simeq 5$ (see http://etacar.fcaglp.unlp.edu.ar/plots/historic.jpg).
An issue in "seeing" Eta Car with the naked eye is that it is mixed up in a lot of bright nebulosity, so it is hard to say to what extent you are seeing the star or the star plus a lot of its surroundings - see below for a Digitized Sky Survey image - messy!
R-band DSS image covering 30x30 arcminutes (size of the full moon) around Eta Car
ProfRob
  • 141,325
Rho Cassiopeiae is my favourite candidate. I know it is a variable but is visible at present on very clear nights. One of the reasons for choosing it is that it is listed as being 8,200 light years away (further in some lists) which means that light was on its way from it 6,000 years ago when some say the universe was created. This would require the light to have been created in transit. Cassiopeiae is easy to spot and Rho is slightly up from the top of the W when the Big Dipper is below Polaris.
Here are a bunch of Gaia DR3 (2022) results, and code to facilitate further study.
It seems clear that under the right conditions, we can see stars at least 10,000 light years away! But note that the answers to this question are around the accuracy limit of even Gaia's parallax data, so I present a range of possibilities, not a definitive conclusion.
Most of the previous answers were before even Gaia DR1 came out in 2016. The best previous data from the 2011 Extended Hipparcos compilation was limited to an accuracy of about 1 mas, giving them perhaps 10% error at just 350 light years. Gaia DR3 parallaxes are accurate to about 0.03 mas for stars brighter than 15th magnitude (though as I understand it, stars brighter than G ≈ 5 mag start to saturate Gaia's CCDs, making precise centroiding difficult). This still means that distance estimates for stars beyond perhaps 10,000 ly tend to have significant errors.
I should also note that data other than parallax measurements can also be helpful. And I'll add that real-world observations, especially for those stars nearer the limits of human seeing, should be incorporated!
But for now I'll just provide the results of an analysis of the Gaia data. This comes from my open-source code farthest-naked-eye-star to facilitate further improvements.
The code produces two results, one based on nominal parallaxes, and one produced by adding Gaia's parallax_error data for each star to the parallax to create a lower bound distance, as others have suggested.
Gaia records brightness using the "G" passband, between about 330 nm and 1050, vs the V passband intended to model human perception, which I think is based on just the wavelengths between 500 and 600 nm. The code gets V magnitudes from SIMBAD.
I did some initial queries which suggest that it is common for the G magnitude to be significantly less than V, but rare to find stars with G larger than 6.2, yet V less than 6.0. So the results shown here use a hard cutoff of G < 6.2.
This script implements the following strategy for selecting stars:
  • Query Gaia DR3 for stars with Gmag < 6.2
  • Compute nominal and conservative lower-bound distances (in ly).
  • Form two candidate tables: one sorted by nominal distance and one by lower-bound distance.
  • Initially select the top 50 candidates from each.
  • Enrich each candidate with SIMBAD data:
    • SIMBAD main identifier, common name, Vmag, spectral type, luminosity class, variable star type.
  • Then filter each table to keep only those with Vmag < 6.0. That leaves 19 nominal candidates and 16 lower-bound candidates.
Here is the result sorted by lower-bound. If you scroll to the right you'll get the Gaia DR3 id for each star. Also note that the latest versions of these three tables can be found as csv files in that same github repository for the source code.
main_id common Vmag Gmag plx plx_err ly_nom ly_lb Con RA Dec spec lum var Gaia DR3
* rho Cas TIC 65366071 4.590 4.050 -0.05693 0.09455 -1 86705 Cas 358.59593 57.49937 G2_0 1998148532777850880
V* V810 Cen TIC 322418709 5.030 4.792 0.15369 0.09270 21222 13238 Cen 175.87991 -62.48939 G0_0-IaFe1 Ia 5333358794709001216
* phi Cas TIC 332680754 4.980 4.736 0.21417 0.08385 15229 10944 Cas 20.02047 58.23161 F0Ia Ia 413828761929696256
V* V509 Cas TIC 313555973 5.130 4.999 0.25073 0.06327 13008 10387 Cas 345.02123 56.94537 G4_0 2009856132592845568
* x Car TIC 306916925 3.830 3.557 0.22276 0.10044 14642 10092 Car 167.14740 -58.97503 G5_0-Ia Ia 5337891256535666176
* mu. Cep TIC 260614141 4.080 2.451 0.11902 0.26369 27403 8522 Cep 325.87694 58.78003 M2-Ia Ia 2202630001603369856
* omi01 Cen TIC 451860101 5.097 4.724 0.32537 0.07341 10024 8179 Cen 172.94191 -59.44205 G3_0-Ia Ia 5336490478704008960
HD 102878 TIC 303884894 5.702 5.591 0.36989 0.03657 8818 8024 Cen 177.61359 -62.64938 A2Iab Ia 5334608080460780672
HD 70761 IDS 08186-2602 AB 5.883 5.789 0.35960 0.05370 9070 7892 Pup 125.70805 -26.34820 F2Iab Ia 5695101727992548224
HD 12953 TIC 374968886 5.680 5.477 0.38407 0.04746 8492 7558 Per 32.16907 58.42360 A1Ia Ia 506778691804372736
HD 199478 TIC 468549377 5.640 5.532 0.39151 0.04014 8331 7556 Cyg 313.95750 47.41764 B7Ia Ia 2166846047768767488
* 3 Gem GEN# +1.00042087 5.750 5.736 0.38778 0.06161 8411 7258 Gem 92.43327 23.11345 B2.5Ib Ib 3425306173127304448
* z02 Car LLNS 4103 5.190 5.038 0.38506 0.07002 8470 7167 Car 167.14160 -61.94717 B9.5Ia Ia 5337105105696383360
HD 111904 LLNS 9341 5.770 5.635 0.44359 0.03096 7353 6873 Cru 193.34119 -60.32849 B9Iab Ia V* 6056408567538569088
* y Car TIC 467274664 4.620 4.431 0.39320 0.08828 8295 6774 Car 168.15000 -60.31762 A5Iae: Ia 5337672556798367360
HD 111613 TIC 435684037 5.720 5.583 0.45345 0.02962 7193 6752 Cru 192.82486 -60.32979 B9.5Iab Ia 6056416676437740416
Note that Rho Cas, which tops the list, has a small negative nominal parallax of -0.05693 mas. Along with the huge parallax error estimate, this indicates that the data is spurious, though negative values can also reflect some systematic errors. See an interesting discussion of negative parallaxes. Recent papers on Rho Cas adopt a value of 2500 pc, or 8200 ly.
Here is the nominal data.
HD 152234 TIC 339565401 5.450 5.424 0.15988 0.34058 20399 6517 Sco 253.50765 -41.80640 B0.5Ia Ia 5966510057279631488
HD 135345 TIC 307739457 5.171 5.064 0.29684 0.44906 10988 4373 Lup 229.01671 -41.49118 A/F 6004302402223120512
* 6 Cas A ADS 17022 A 5.590 5.293 0.42644 0.06598 7648 6624 Cas 357.20901 62.21451 A3Ia Ia 2012942564813958656
* b Vel TIC 141901042 3.810 3.554 0.43116 0.10079 7565 6131 Vel 130.15651 -46.64872 F0Ia Ia V* 5521599549054493696
* psi01 Aur TIC 258622975 4.750 4.122 0.44257 0.11030 7370 5899 Aur 96.22459 49.28788 K5-M1Iab-Ib Ia 970675154497903616
The code can also be used with a custom WHERE clause in the Gaia ADQL query. I've used that to pull in data for most of the other candidates I've encountered in answers here and at What is the farthest star visible naked-eye? - Deep Sky Observing - Cloudy Nights (free login needed).
given_name Gaia DR3 main_id common Vmag Gmag plx plx_err ly_nom ly_lb Con RA Dec spec lum var
vv cep 2216536246703152256 V* VV Cep ** WRH 36 4.900 3.940 1.00331 0.10731 3251 2937 Cep 329.16308 63.62555 M2Ibep+B2?ep_sh Ib
VY Canis Majoris 5616197646838713728 NAME VY CMa B ** B 719B 10.340 7.352 0.41918 0.40791 7781 3943 CMa 110.74301 -25.76754
NML Cygni 2065235853217670656 NML Cyg OH 080.8-01.9 11.148 0.52792 0.34798 6178 3724 Cyg 311.60641 40.11649 M7/8
Eta Carinae 5350358584482202880 * eta Car SRGA J104503.3-594104 6.480 4.035 NaN NaN -1 -1 Car 161.26474 -59.68446 LBV V
v762 cas 534889699426804224 HD 7389 TIC 352284047 5.860 4.952 1.31483 0.06929 2481 2356 Cas 19.04957 71.74385 K5
HIP 107418 2203889767044993920 * nu. Cep TIC 408093341 4.290 4.121 0.93209 0.08651 3499 3202 Cep 326.36216 61.12080 A2Iae Ia
HIP 22783 482818271843093376 * alf Cam TIC 281696989 4.290 4.213 0.59157 0.13331 5513 4499 Cam 73.51255 66.34271 O9Ia Ia
HIP 54463 5337891256535666176 * x Car TIC 306916925 3.830 3.557 0.22276 0.10044 14642 10092 Car 167.14740 -58.97503 G5_0-Ia Ia
HIP 107259 2202630001603369856 * mu. Cep TIC 260614141 4.080 2.451 0.11902 0.26369 27403 8522 Cep 325.87694 58.78003 M2-Ia Ia
HIP 51623 5351420437845776256 HD 91533 TIC 457766442 6.006 5.885 0.41050 0.02530 7945 7484 Car 158.19915 -58.66673 A2Iab/b Ia
HIP 52405 5350406619413548032 HD 92964 WISEA J104240.58-591256.7 5.510 5.272 0.47152 0.06689 6917 6058 Car 160.66897 -59.21575 B2.5Ia Ia
HIP 51192 5351701122540337792 V* V399 Car TIC 464732822 4.700 4.483 0.49759 0.11508 6555 5324 Car 156.85190 -57.63879 A9/F0Ia/ab Ia
HIP 52004 5350668303173229824 HD 92207 LLNS 2006 5.450 5.226 0.46747 0.06164 6977 6164 Car 159.36272 -58.73332 A0Ia Ia
HIP 112444 2705401759471719168 HD 215667 AP J22464026+0454287 7.830 7.794 5.63308 0.02832 579 576 Peg 341.66778 4.90799 A7IV I
HIP 80493 6045440595422971776 HD 147955 AP J16255065-2634062 7.270 8.037 5.88106 0.40924 555 519 Sco 246.46101 -26.56850 B9V V
Beta Phoenicis 4933453324590295040 * bet Phe A WDS J01061-4643A 4.000 3.744 NaN NaN -1 -1 Phe 16.52096 -46.71839
AH Sco 5979926504430920192 V* AH Sco TIC 45344564 8.100 6.031 0.56324 0.07988 5791 5071 Sco 257.82090 -32.32521 M5Ia-Iab Ia
rw cep 2005992002061917312 V* RW Cep TIC 422108142 6.650 5.585 0.11398 0.03425 28616 22004 Cep 335.77920 55.96322 K2_0-Ia Ia
V640 Mon 3131898712120792064 HD 47129 TIC 220197273 6.060 6.016 0.76148 0.07008 4283 3922 Mon 99.35017 6.13539 O8I+O7.5III I
AO Cas 394976501194687488 V* AO Cas TIC 202133804 6.140 6.089 0.75456 0.05794 4322 4014 Cas 4.42941 51.43308 O9.2II+O8V((f)) II
HD 041161 969823376583544576 HD 41161 TIC 416954881 6.764 6.721 0.67137 0.06053 4858 4456 Aur 91.46855 48.24928 O8Vn V
HD 057682 3047763601330845312 HD 57682 TIC 187458882 6.430 6.375 0.89681 0.07394 3637 3360 Mon 110.50860 -8.97932 O9.2IV I
P Cygni 2061242908036996352 * P Cyg TIC 12149245 4.820 4.566 0.62508 0.07292 5218 4673 Cyg 304.44665 38.03290 B1-2Ia-0ep Ia
EZ CMa 2922367976673391232 HD 50896 TIC 78959225 6.910 6.583 0.65045 0.03662 5014 4747 CMa 103.55433 -23.92833 WN4b
HD 30353 204531088580182016 HD 30353 LAMOST J044854.23+431639.2 7.760 7.485 0.10037 0.04142 32496 23004 Per 72.22229 43.27557 A5Iap Ia
HD 62745 3028867978609417344 HD 62745 TIC 333817448 8.390 7.183 0.17281 0.02510 18874 16480 Pup 116.23747 -15.69722 M3.3Iab Ia
HD 48716 3352789979664648064 HD 48716 LAMOST J064514.54+132017.6 7.270 7.179 0.14995 0.02512 21751 18630 Gem 101.31075 13.33593 A0
68 Cygni 1971467916750747264 * 68 Cyg TIC 138317746 5.000 4.992 1.44978 0.11521 2250 2084 Cyg 319.61330 43.94591 O7.5IIIn((f)) III
nealmcb
  • 471
The Extended Hipparcos compilation (Anderson+, 2012) provides distances for stars in the Hipparcos catalogue, together with the apparent magnitude in Johnson V (which approximates to how bright a star appears to be to the human eye).
The distance calculation is Dist = 1000/Plx * (1+1.2*(e_Plx/Plx)^2).
Applying the search criteria Vmag<6 & Dist>0 (i.e. not null) identifies 4 stars in Carina that are over 2450 parsecs (over 8000 light-years), all of which are "single components", with some degree of variability:
HIP 51623=HR 4144 2497pc Vmag=5.98 (var < 0.06mag; Hpmag = 6.075)
HIP 52405=HR 4198 (V519 Car) 2492pc Vmag=5.36 (0.06mag < Var < 0.6 mag; Hpmag = 5.446)
HIP 51192=HR 4110 (V399 Car) 2484pc Vmag=4.65 (var < 0.06mag; Hpmag = 4.778)
HIP 52004=HR 4169 (V370 Car) 2475pc Vmag=5.47 (0.06mag < Var < 0.6 mag; Hpmag = 5.47)
Depending on how reliable the distances listed are, any of these might be worthy candidates.
