Approaching a black hole event horizon, I would see time pass more quickly outside.
In practical terms, let's assume I am approaching a supermassive black hole whose tidal forces I might survive at the horizon (let's say it's Saggitarius A*). I know that I wouldn't see infinite time pass as I crossed the horizon , but could I survive all the radiation from the "not quite infinite" amount of time (and presumably blue-shifted light?) I would be observing?
I've tagged this as "black-hole-firewall" because it sounds like a similar concept, but my question isn't motivated by information loss so I think it might be unrelated.
quant
  • 250
It depends on exactly how you approach the horizon.
You mention the firewall but this is a quantum effect and is not universally accepted, so let's stick to classical general relativity. If you hover at a fixed distance outside the black hole event horizon then the light reaching you from the rest of universe is blue shifted and increased in intensity. As you reduce the distance from the horizon at which you hover then the blue shift and intensity increase and indeed go to infinity as you approach the horizon. In this case you can indeed add roasting to the ways a black hole can kill you.
However this only applies when you are hovering. If you are falling freely into the black hole then the light reaching you from the rest of the universe is red shifted not blue shifted. A rigorous proof of this is rather involved, but I give a heuristic proof in my answer to Do free falling observers see gravitational blueshift? You would fall through the horizon with any incendiary side effects.
John Rennie
  • 367,598
