34
I know that a supernova can mess up the heliosphere of nearby stars, but I'm wondering if it could physically push neighboring stars off their trajectories.
It's fun to imagine all the stars surrounding a supernova being propelled outward and tumbling out of the galactic arm!
I would expect that a really close star, such as a partner in a binary pair, would get really messed up. I'm thinking more about the neighbors a few light-years away.
I realize that a supernova involves both the initial EM burst and the mass ejection which arrives later. I'm open to the effects of any of these things.
Kyle Oman
  • 18,883
  • 68
  • 125
SlowMagic
  • 1,053
Consider a star of mass $M$ and radius $R$ at a distance $r$ from the supernova. For a back-of-the-envelope estimate, consider how much momentum would be transferred to the star by the supernova. From that, we can estimate the star's change in velocity and decide whether or not it would be significant.
First, for extra fun, here's a review of how a typical core-collapse supernova works [1]:
Nuclear matter is highly incompressible. Hence once the central part of the core reaches nuclear density there is powerful resistance to further compression. That resistance is the primary source of the shock waves that turn a stellar collapse into a spectacular explosion. ... When the center of the core reaches nuclear density, it is brought to rest with a jolt. This gives rise to sound waves that propagate back through the medium of the core, rather like the vibrations in the handle of a hammer when it strikes an anvil. .. The compressibility of nuclear matter is low but not zero, and so momentum carries the collapse beyond the point of equilibrium, compressing the central core to a density even higher than that of an atomic nucleus. ... Most computer simulations suggest the highest density attained is some 50 percent greater than the equilibrium density of a nucleus. ...the sphere of nuclear matter bounces back, like a rubber ball that has been compressed.
That "bounce" is allegedly what creates the explosion. According to [2],
Core colapse liberates $\sim 3\times 10^{53}$ erg ... of gravitational binding energy of the neutron star, 99% of which is radiated in neutrinos over tens of seconds. The supernova mechanism must revive the stalled shock and convert $\sim 1$% of the available energy into the energy of the explosion, which must happen within less than $\sim 0.5$-$1$ s of core bounce in order to produce a typical core-collapse supernova explosion...
According to [3], one "erg" is $10^{-7}$ Joules. To give the idea the best possible chance of working, suppose that all of the $E=10^{53}\text{ ergs }= 10^{46}\text{ Joules}$ of energy goes into the kinetic energy of the expanding shell. The momentum $p$ is maximized by assuming that the expanding shell is massless (because $p=\sqrt{(E/c)^2-(mc)^2}$), and while we're at it let's suppose that the collision of the shell with the star is perfectly elastic in order to maximize the effect on the motion of the star. Now suppose that the radius of the star is $R=7\times 10^8$ meters (like the sun) and has mass $M=2\times 10^{30}$ kg (like the sun), and suppose that its distance from the supernova is $r=3\times 10^{16}$ meters (about 3 light-years). If the total energy in the outgoing supernova shell is $E$, then fraction intercepted by the star is the area of the star's disk ($\pi R^2$) divided by the area of the outgoing spherical shell ($4\pi r^2$). So the intercepted energy $E'$ is $$ E'=\frac{\pi R^2}{4\pi r^2}E\approx 10^{-16}E. $$ Using $E=10^{46}$ Joules gives $$ E'\approx 10^{30}\text{ Joules}. $$ That's a lot of energy, but is it enough? Using $c\approx 3\times 10^8$ m/s for the speed of light, the corresponding momentum is $p=E'/c\approx 3\times 10^{21}$ kg$\cdot$m/s. Optimistically assuming an elastic collision that completely reverses the direction of that part of the shell's momentum (optimistically ignoring conservation of energy), the change in the star's momentum will be twice that much. Since the star has a mass of $M=2\times 10^{30}$ kg, its change in velocity (using a non-relativistic approximation, which is plenty good enough in this case) is $2p/M\approx 3\times 10^{-9}$ meters per second, which is about $10$ centimeters per year. That's probably not enough to eject the star from the galaxy. Sorry.
References:
[1] Page 43 in Bethe and Brown (1985), "How a Supernova Explodes," Scientific American 252: 40-48, http://www.cenbg.in2p3.fr/heberge/EcoleJoliotCurie/coursannee/transparents/SN%20-%20Bethe%20e%20Brown.pdf
[2] Ott $et al$ (2011), "New Aspects and Boundary Conditions of Core-Collapse Supernova Theory," http://arxiv.org/abs/1111.6282
[3] Table 9 on page 128 in The International System of Units (SI), 8th edition, International Bureau of Weights and Measures (BIPM), http://www.bipm.org/utils/common/pdf/si_brochure_8_en.pdf
Chiral Anomaly
  • 55,710
  • 99
  • 166
27
Probably not. Supernovae are powerful, but space is really big. ;)
Supernova energies are often measured in foe; one foe is $10^{44}$ joules. According to Wikipedia, a big supernova can release around 100 foe. The energy of the released neutrinos in a core-collapse supernova is higher than the EM energy, but that's only an issue if you're really close to the supernova.
From Wikipedia:
There is a fundamental difference between the balance of energy production in the different types of supernova. In type Ia white dwarf detonations, most of the energy is directed into heavy element synthesis and the kinetic energy of the ejecta.[174] In core collapse supernovae, the vast majority of the energy is directed into neutrino emission, and while some of this apparently powers the observed destruction, 99%+ of the neutrinos escape the star in the first few minutes following the start of the collapse.[47]
By way of comparison, the Sun's gravitational binding energy (GBE) is around $3.8 \times 10^{41}$ joules. So if a sun-like star got hit by one thousandth of the light energy released by a supernova it would get seriously messed up.
But as I said at the start, space is really big. If you spread 1 foe of energy over the surface of a sphere of 1 light-year radius, an area on that sphere equal to the Sun's cross-section would get around $1.35 \times 10^{29}$ joules, which is a substantial quantity of energy, but it's around a trillionth of the Sun's GBE. So a supernova may do interesting things to the atmosphere of a star 1 light-year away, and the atmospheres of any planets in that system, but it won't disrupt the star, or cause a noticeable perturbation of its galactic orbit.
However, supernova explosions are notoriously asymmetrical. The energy and matter they release is not spread uniformly over a nice spherical surface. So there's a chance that the damage at 1 light-year is much worse than what I stated in the previous paragraph. In particular, the supernova remnant (the neutron star or black hole produced by the collapse) may be ejected at 500 km/s or faster. If you happen to be in the path of one of those, Bad Things are likely to occur. An extreme example is Pulsar B1508+55, a neutron star heading out of the galaxy at 1100 km/s.
PM 2Ring
  • 13,541
14
It actually can, through gravity. This is a mechanism some people use to explain why the dark matter density profile is not "cuspy" in dwarf galaxies. The idea is fairly simple: a super nova explodes, it pushes out gas. The gas is coupled through gravity with dark matter, so dark matter is also moved around. This changes the potential of the galaxy, which in turn makes the orbits of the stars change close to the center.
More formally, the potential energy required to assemble the dark halo is
$$ W_{\rm DM} = -4\pi G \int_0^{R_{\rm vir}}{\rm d}r ~ \rho(r)M(r) r \tag{1} $$
with $\rho$ its density, and $M$ its cumulative mass profile. $R_{\rm vir}$ is the virtual radius of the galaxy, which for a dwarf spheroid is a few kpc. The energy released by SNe is
$$ E_{\rm SN} = \frac{M_\star}{\langle m_\star\rangle}\xi(m_\star > 8 M_{\odot}) E_{\rm SN} \tag{2} $$
where $M_{\rm star}$ is the total stellar mass of the galaxy, $\langle m_\star\rangle$ is the average stellar mass, $\xi$ is the initial mass function of which only the upper tail is considered since the fraction producing stars with $m_{\star} < 8 M_{\odot}$ will not result in SNe, $E_{\rm SN}$ is the energy released in a SNII explosion.
Now, some of this released energy goes through transform the orbits of the DM particles, let's say a small fraction $\eta$. The important question is then: imagine you start with a galaxy with gravitational energy $W_{\rm DM}^{(1)}$, and want to transform it to a galaxy with gravitational energy $W_{\rm DM}^{(2)}$, can we do it with the amount of energy $\eta E_{\rm SN}$?
$$ 2\eta E_{\rm SN} > W_{\rm DM}^{(2)} - W_{\rm DM}^{(1)} \tag{3} $$
And the answer is a solid yes. You can see a couple of references here for more details.
  1. Cuspy No More: How Outflows Affect the Central Dark Matter and Baryon Distribution in Lambda CDM Galaxies
  2. The coupling between the core/cusp and missing satellite problems
  3. Cusp-core transformations in dwarf galaxies: observational predictions
It clearly depends on what the final product $W_{\rm DM}^{(2)}$ looks like, but it is definitely able to transform a galaxy with a density profile of the form $\rho \sim r^{-1}$ to galaxy with a density profile $\rho \sim 1$ for small $r$ in a reasonable time scale.
caverac
  • 6,802
