Too much density and the universe is closed, analogous to a sphere in four dimensions: you travel in a straight line and you end up where you started. Too little and you have a saddle: not sure about the destination if you travel in a straight line. Just the right amount and the topology is flat. The flat topology is infinite: you travel in a straight line forever.
If the topology is flat (and at this point all evidence indicates that it is to within 0.4%), then multiplying the critical density by an infinite amount of cubic meters gives you an infinite energy/stress.$$\rho_{CRIT}\space kg\space m^{-3}\times \infty\space m^3=\infty\space kg$$
Is that a reasonable interpretation?
What you calculated above ($\infty$, for a flat space universe) is just the proper mass-energy of matter. It doesn't take into account the - negative - energy of the gravitational "field" itself, which cannot be localised in General Relativity. The "total energy" of the universe could be 0, but there's no way we could give a physical sense to it, since the whole universe energy cannot be measured from "inside".
Cham
  • 8,015
You have to be careful with the interpretation of energy when you don't know what sort of gravitational potential well might be involved. For example, you might find some amount $m c^2$ of rest-energy of matter when calculated in an inertial frame near but outside the horizon of a black hole, but in order to use this energy at some other location, you would first have to pull the matter up against gravity, expending energy $E$ in order to do so. After spending that $E$ you acquire just $m c^2$ at your location, so overall you have gained $(m c^2-E)$ and this will be small compared to $m c^2$ if the matter started out near a horizon. This is the sense in which gravitational binding energy is negative. When applied to the whole universe, this consideration makes a calculation of the type you are proposing questionable, because it is hard to say what physical meaning it has.
A better analogy is, perhaps, with the concept of escape velocity. A flat universe is one where the motion of matter everywhere is just enough to keep escaping from its own mutual gravity.
Finally, the topology of a mathematical space is not in one-to-one correspondence with the curvature, and in particular, if a space is flat it does not necessarily follow that it is infinite. There are a number of different topologies that are mathematically possible for a flat space, and some of them are bounded (i.e. not infinite). So this may apply to the physical universe too. We don't know.
Andrew Steane
  • 65,285
-3
If it was completely flat, you wouldn't talk about volume. The universe isn't completely flat, it does have a volume (like a pancake, it's called 'flat', but it definitely has a volume). For a truly flat object, your formula would need a surface density and surface area, and you would get a finite answer.
Bas
  • 145
