Consider one parameter transformation: $y = y ( \tilde{y}, \alpha)$ such that lagrangian satisfies: $\tilde{L}(\tilde{y}, \alpha) = L(y ( \tilde{y}, \alpha))$. We say that equation is invariant under this transformation if: $$\tilde{L}(\tilde{y}, \alpha) = L(\tilde{y}) + \frac{dF(\tilde{y},\alpha)}{dt}$$ Show that: $$\int \frac{\delta L}{\delta y_t} \frac{\partial y}{\partial \alpha} dx - \frac{\partial F}{\partial \alpha}$$ is a constant of motion.
Here $\tilde{y}$ is an old field before transformation, so is lagrangian $\tilde{L}$. Space is 2-dimensional $(x, t)$ and the exercise is listed in section concerning KdV equation.
Any hints?
qoqosz
  • 837
Since OP's problem looks like a homework assignment, we will only provide OP with a series of hints rather than a full solution.
I) The Lagrangian $L~=~\int \! dx ~{\cal L}$ is the spatial integral of the Lagrangian density ${\cal L}$. Let us call the position field $q(x,t)$ and the corresponding velocity field $v(x,t)$. The Lagrangian $L[q(\cdot,t),v(\cdot,t)]$ is a functional of the position and the velocity fields, cf. e.g. this Phys.SE answer. The momentum field is the functional derivative
$$ \tag{1} p(x,t)~:=~\frac{\delta L[q(\cdot,t),v(\cdot,t)]}{\delta v(x,t)}.$$
An infinitesimal variation $\delta L$ of the Lagrangian functional $L$ is given by $$\tag{2} \delta L~=~\int \! dx~\left( \frac{\delta L}{\delta q}\delta q+\frac{\delta L}{\delta v}\delta v \right). $$ The exercise basically asks OP to derive a functional version of Noether's Theorem, which he probably knows for ordinary point mechanics.
II) Let $$\tag{3} \delta q~=~\varepsilon Y$$ be an infinitesimal variation of the position field, where $\varepsilon$ is an infinitesimal constant, and where $Y$ is the generator. Correspondingly, the velocity field transforms as $$\tag{4}\delta v~=~\varepsilon \dot{Y}.$$ (The transformation (3) is a so-called vertical transformation. In general, one could also allow horizontal contributions from variation of $x$ and $t$.)
III) Assume that the transformation (2) is a so-called quasi-symmetry $$\tag{5} \delta\left(\left. L \right|_{v=\dot{q}}\right)~=~ \varepsilon\frac{d}{dt} \left(\left. F\right|_{v=\dot{q}}\right),$$ where $F[q(\cdot,t),v(\cdot,t)]$ is some functional. (If $F=0$ is zero, then the quasi-symmetry becomes a symmetry of the Lagrangian $L$.)
IV) The (temporal component of the) bare Noether current $j^0$ for a vertical transformation (3) is simply the momentum field $p$ times the vertical generator $Y$,
$$\tag{6} j^0 ~:=~p Y. $$
The bare Noether charge $Q^0$ is the spatial integral
$$\tag{7} Q^0 ~:=~ \int \! dx~j^0. $$
The full Noether charge $Q$ is improved with (minus) the $F$-functional,
$$\tag{8} Q ~:=~Q^0-F. $$
Formula (8) corresponds to OP's last formula (v1). Noether's Theorem states that $Q$ is a conserved quantity on-shell, i.e. if the equation of motion
$$\tag{9} \left.\frac{d}{dt} \left(\frac{\delta L}{\delta v}\right|_{v=\dot{q}}\right)~=~\left. \frac{\delta L}{\delta q}\right|_{v=\dot{q}} $$
is satisfied. The proof in the functional setting is very similar to the usual proof given in ordinary point mechanics.
