I have been thinking on the effect of the centrifugal/centripetal forces from the orbital movement of the earth around the sun, which might perhaps affect the gravity.
In nighttime we are on the outside of the orbital path and in daytime we are on the inside, facing the sun. We would then, to my belief, in daytime be "pushed harder" to the ground, and in nighttime this force would be in the opposite direction from the ground.
Using the formula for determining the centrifugal force I have come to the conclusion that for a normal human it should be in the order of 0.5 Newton
Is this thinking correct or have I missed something important? If correct, is this difference in gravity measurable or deteminable?
Beta
  • 109
Centripetal forces do not affect gravitational forces. All the forces add to a net force.
Given the Earth's orbital motion around the sun, the effective force you would feel towards the center of the Earth is indeed smaller (assuming you're not standing on the top of the Earth).
There is also an effect on the apparent gravity by Earth's own rotation.
psitae
  • 1,455
  • 15
  • 29
