For a sharp cut-off regularization, we introduce the UV cutoff $\Lambda$. When we need to do momentum integral, we integrate the momentum ball with radius $\Lambda$. This $\Lambda$ has the explicit physical meaning of UV cutoff.
For $\phi^4$ in $4$-dim, when we use dimensional regularization, we introduce an arbitrary mass scale $\mu$ $$S= \int d^Dx \frac{1}{2} (\partial_\mu \phi)^2 + \frac{m^2}{2} \phi^2+ \frac{\lambda \mu^\epsilon}{4!} \phi^4 $$ with $\epsilon = 4-D$.
Up to now, the introduction of the arbitrary mass scale $\mu$ is just to keep parameter $\lambda$ dimensionless. It can be any number. But when we write the RG equation and beta function, we give the $\mu$ physical meaning of a UV cutoff. However textbook doesn't explain why.
My question:
  1. Why does this arbitrary mass scale $\mu$ has the physical meaning of UV cutoff?
maplemaple
  • 2,217
Dude, you are confused! In the dimensional renormalization scheme (Feynman used to call the shell game of renormalization dippy Hocus-Pocus), it's the $\epsilon = 4-d$ which plays the role of UV cutoff.
The renormalization scale $\mu$ is the energy scale ($p^2 \sim \mu^2$) you anchor your renormalized parameters, such as coupling $g_{renor}|_{p^2=\mu^2}$, Usually, $\mu$ is chosen at the physical process scale in concern, rather than an UV cutoff scale $\Lambda$ which is assumed to be close to the Planck scale $M_p$.
MadMax
  • 5,451
  • 13
  • 42
