  1. Does electron's magnetic spin mean that we can think of it as having the two magnetic poles?
  2. Does the spin mean that it generates magnetic field even if it is at rest?
I expect to get 'no' to both questions because we always say moving charges generate magnetic field. And I hope to see answers which will clear my confusion.
Emilio Pisanty
  • 137,480
physicsguy19
  • 1,512
Yes. There are no known magnetic monopoles, see: Magnetic Monopoles
Yes, but as regards "at rest", you should read this answer: Electron at rest
Magnetic spin isn't really a proper term, but an electron's spin is directly linked to its magnetic field, if we were to say that only moving electric charges produce magnetic fields, we would have trouble explaining how a static magnetic "works".
I would also stress that spin in this case is purely a mathematical idea, an electron does not resemble a very small rotating football in this case, its a bad choice of words made years ago.
If you read the links, you will get a better answer than this short reply.
The electron can be seen as a small magnet with the field of a magnetic dipole of strength $2\mu_B \vec S$. So my answer is yes in both cases. I interpret as at rest a state in which the electron has zero momentum expectation value. Note that there is no accepted model of spin as a rotation, although spin is an angular moment to every effect.
Emilio Pisanty
  • 137,480
my2cts
  • 27,443
