Is it possible for holograms, as in 3D projections of light in midair, to exist? enter image description here
Consider this image. If a projector, placed in the same position as the gray circle in the first image, were to project some sort of light into the air, would it be able to form a three-dimensional image such as this bowl?
umntc
  • 295
If the question is about holograms per se, the answer is "no": The image displayed by a hologram is always between the observer and the hologram, or else the hologram is between the observer and the image (like a window).
But if the question is about the possibility of projecting a 3D image into mid-air without anything the observer must look through or against, then the answer is "yes". I know of one approach, which is to use a laser with sufficient power to ionize the air at a focal point, causing the air to glow. The focal point can be scanned to draw a 3D image. This kind of image is visible from all directions.
S. McGrew
  • 25,240
  • 32
  • 81
