In quantum field theory, with the field $\phi$ and the momentum $\pi$ being operators, their time evolution is governed (in the Heisenberg-picture) by the Heisenberg equation:
\begin{align} \dot{\phi} = \frac{i}{\hbar}[ \hat{H}, \phi] \\ \dot{\pi} = \frac{i}{\hbar}[ \hat{H}, \pi]. \\ \end{align}
Now, in case the Hamiltonian operator $\hat{H}=\int d^3x ~\hat{\cal H}$ can be written as an integral over the hamiltonian density $\hat{\cal H}$, and the fields and the momenta commute at non-equal positions, do the same equations hold as well with the Hamiltonian operator being replaced by it's density? What would the caveats be?
\begin{align} \dot{\phi} = \frac{i}{\hbar}[ \hat{\cal H}, \phi] \\ \dot{\pi} = \frac{i}{\hbar}[ \hat{\cal H}, \pi]. \\ \end{align}
Quantumwhisp
  • 7,095
  1. The answer is No. For starters for dimensional reasons. A density carries dimension $L^{-3}$.
  2. In the classical (as opposed to the quantum) case, it is tempting to (at least partially) incorporate OP's suggestion for functionals $$ F~=~\int \! d^3x~f(x), \qquad G~=~\int \! d^3x~g(x), \tag{1} $$ by changing the definition from the standard field-theoretic canonical Poisson bracket $$\begin{align}\{ F, G\} ~:=&~\int_V \! d^3x ~\left(\frac{\delta F}{\delta \phi (x)}\frac{\delta G}{\delta \pi (x)}-\frac{\delta F}{\delta \pi (x)}\frac{\delta G}{\delta \phi (x)} \right)\cr ~=~&\int_V \! d^3x ~\{\!\{ f(x),g(x)\}\!\}\end{align} \tag{2}$$ to a same-$x$ Poisson bracket $$ \{\!\{ f(x),g(x)\}\!\} ~:=~\frac{\delta f(x)}{\delta \phi (x)}\frac{\delta g(x)}{\delta \pi (x)}-\frac{\delta f(x)}{\delta \pi (x)}\frac{\delta g(x)}{\delta \phi (x)}, \tag{3} $$ where $\delta f(x)/\delta \phi (x)$ denote a same-spacetime functional derivative, see e.g. my Phys.SE answer here. In other words, the non-zero fundamental Poisson brackets read $$\{ \phi(x),\pi(y) \} ~=~\delta^3(x\!-\!y)\qquad\text{and}\qquad \{\!\{ \phi(x),\pi(x) \}\!\} ~=~1,\tag{4}$$ i.e. the same-$x$ Poisson bracket (3) is defined without a Dirac delta distribution. However, in the $x$-local $\{\!\{\cdot,\cdot\}\!\}$ formalism (3) equality signs typically only hold modulo total spacetime derivative terms.
You have $\hat{H} = \int d^3x \hat{\tilde{H}}(x)$. That implies that canonical Relations will be slightly altered.
For a Quantum field Operator $\hat{\phi}(x',t)$ distributed over space $x'$ and time $t$, you will have a relation like the following:
$[\hat{\tilde{H}}(x),\hat{\phi}(x',t)] = \frac {\partial}{\partial t} \hat{\phi(x',t)} \delta(x-x')$.
The Delta function factor ensures not only the commutation of Operators for nonequal space Points; also that after Integration over space, the ordinary commutation Relations are obtained
kryomaxim
  • 3,558
