Frankly, complex angles just aren't worth the hassle. As the answer you've linked to points out, they're just a complicated way to re-parametrize the evanescent wave
e^{i\mathbf k\cdot \mathbf r}
= e^{i(k_x,0,i\kappa)\cdot (x,y,z)}
=e^{ik_x x}e^{-\kappa z}
\ \ \stackrel{\rm as}{=} \ \
e^{ik(\sin(\theta),0,\cos(\theta))\cdot\mathbf r}
For the total-internal-reflection case that you ask about, take the form above for the evanescent wave in medium $2$ for $z>0$, so that you're required to have
k_x^2 -\kappa^2 = k_2^2 = \frac{n_2^2}{n_1^2} k_1^2.
With that notation in place, any angle that fulfills the equations
\begin{align}
k_2 \sin(\theta) & = k_{x,1} \\
k_2 \cos(\theta) & = i\kappa,
\end{align}
or equivalently
\begin{align}
\sin(\theta) & = \frac{n_1}{n_2}\sin(\theta_i) \\
\cos(\theta) & = i\sqrt{ \frac{n_1^2}{n_2^2}\sin^2(\theta_i)-1 }
\end{align}
is an acceptable solution $-$ so long as those two conditions are satisfied, even if you get different $\theta$s, the consequences for the real-world waveforms are exactly identical, and the $\theta$s cannot be differentiated on the basis of any physical observable. On the other hand, it's important to note that both of these conditions need to be satisfied, or you run the risk of having an incorrect sign for $\kappa$ and, with that, an exponentially-increasing wave where you were meant to have a quickly-decaying evanescent wave.
To fully characterize the complex angle, let's work our conditions some more, though, by expanding out the angle into its real and imaginary parts, $\theta = \theta_\mathrm{re}+i \theta_\mathrm{im}$ (with $\theta_\mathrm{re},\theta_\mathrm{im} \in \mathbb R$),
\begin{align}
\sin(\theta_\mathrm{re})\cosh(\theta_\mathrm{im}) + i\cos(\theta_\mathrm{re})\sinh(\theta_\mathrm{im})
\cos(\theta_\mathrm{re})\cosh(\theta_\mathrm{im}) - i\sin(\theta_\mathrm{re})\sinh(\theta_\mathrm{im})
\end{align}
and then requiring that the real and imaginary parts of these equations be satisfied simultaneously,
\begin{align}
\sin(\theta_\mathrm{re})\cosh(\theta_\mathrm{im}) & = \frac{n_1}{n_2}\sin(\theta_i) \\
\cos(\theta_\mathrm{re})\sinh(\theta_\mathrm{im}) & = 0 \\
\cos(\theta_\mathrm{re})\cosh(\theta_\mathrm{im}) & = 0 \\
\sin(\theta_\mathrm{re})\sinh(\theta_\mathrm{im}) & = - \sqrt{ \frac{n_1^2}{n_2^2}\sin^2(\theta_i)-1 }
\end{align}
Since $\theta_\mathrm{im}$ is real, which guarantees that $\cosh(\theta_\mathrm{im})>0$, we conclude from $\cos(\theta_\mathrm{re})\cosh(\theta_\mathrm{im}) = 0$ that
\cos(\theta_\mathrm{re}) = 0
and therefore that
\theta_\mathrm{re} = \frac{\pi}{2} + n \pi, \ \ n\in \mathbb Z,
as a necessary condition, which then implies that $\sin(\theta_\mathrm{re}) = (-1)^n$, so we still need to solve both of
\begin{align}
\cosh(\theta_\mathrm{im}) & = (-1)^n\frac{n_1}{n_2}\sin(\theta_i) \\
\sinh(\theta_\mathrm{im}) & = - (-1)^n\sqrt{ \frac{n_1^2}{n_2^2}\sin^2(\theta_i)-1 }
\end{align}
Here the second equation is always solvable, as
\theta_\mathrm{im} = - (-1)^n\mathrm{arcsinh} \mathopen{}\left(\sqrt{ \frac{n_1^2}{n_2^2}\sin^2(\theta_i)-1 }\right),
and this will guarantee the correct sign for $\kappa$, but the first equation is only possible if $(-1)^n\sin(\theta_i)>0$, where you can conclude that $n$ is even if the incidence angle is counted as positive. This is a reasonable convention, but it is not guaranteed, and a more general solution is to adjust the offset $n$ according to the sign of the incidence angle as
(-1)^n = \mathrm{sgn}(\theta_i),
giving $\theta_\mathrm{re} = \frac{\pi}{2} \ (\mathrm{mod} \ 2\pi)$ for $\theta_i> 0$, and choosing $n=-1$ as the principal representative for the opposite case, $\theta_\mathrm{re} = -\frac{\pi}{2} \ (\mathrm{mod}\ 2\pi)$ for $\theta_i< 0$. This means, then, that the correct solution is
\begin{align}
\theta_\mathrm{re} & = \mathrm{sgn}(\theta_i) \frac{\pi}{2}
\theta_\mathrm{im} & = - \mathrm{sgn}(\theta_i) \mathrm{arcsinh} \mathopen{}\left(\sqrt{ \frac{n_1^2}{n_2^2}\sin^2(\theta_i)-1 }\right),
\end{align}
or in other words
\theta = \mathrm{sgn}(\theta_i) \left[
\frac{\pi}{2} - i\: \mathrm{arcsinh} \mathopen{}\left(\sqrt{ \frac{n_1^2}{n_2^2}\sin^2(\theta_i)-1 }\right)\right] \mod 2\pi
as the general solution.
I've phrased things like this because they're a surefire way to guarantee the correct signs, but it's clunkier than it needs to be, so it can be simplified a bit to swap that arcsinh-of-a-square-root for a simpler arccosh: to do that, start by writing
\begin{align}
\cosh(\theta_\mathrm{im}) & = (-1)^n\frac{n_1}{n_2}\sin(\theta_i) = \frac{n_1}{n_2}\left|\sin(\theta_i)\right|
\end{align}
(since the $(-1)^n$ factor is there to guarantee positivity), allowing you to write
\begin{align}
\theta_\mathrm{im} = \pm \mathrm{arccosh} \mathopen{}\left(\frac{n_1}{n_2}\left|\sin(\theta_i)\right|\right)
\end{align}
up to a sign ambiguity which we've resolved above. With the sign resolution from above, though, we get as our final result
\frac{\pi}{2} - i\: \mathrm{arccosh} \mathopen{}\left(\frac{n_1}{n_2}\left|\sin(\theta_i)\right|\right)\right] \mod 2\pi
