So I am a middle schooler and from what i understand, photons can interact with surrounding particle via gravity. If this is true, would 2 photons on an uninterrupted and completely isolated path eventually gravitate towards each other and pass each other, then gravitate again in an oscillatory fashion, while the distance from an imaginary midpoint slowly decreases. If this would happen, wouldn’t we be incapable of telling this combination of two photons apart from a single photon other than its increased energy than a normal photon and increased gravitational pull.
That is an insightful question. To answer the first part fully would require a LOT of math. Your basic thought is right: photons would attract each other gravitationally. However, the attraction would be very small; much too small to observe or measure using any instrument currently imagined. The second part of your question is
If there were a pair of gravitationally bound photons, a detector would presumably record a double event, having twice the energy of a single photon detection event. But it is not known if it's possible for two photons to be gravitationally bound. Some relevant discussion can be found here.
S. McGrew
  • 25,240
  • 32
  • 81
Let us touch particle base here, because you are talking of photons, and not of light beams.
There is a great difference between a light beam behavior, because it is a classically well modeled state, it has a stress energy tensor and would follow the geodesics of general relativity. As S McGrew states the attraction would be very very small because gravity is a weak force.
But when talking of photons we are no longer in the classical regime, we are in the quantum mechanical frame. Even ignoring gravity, photon photon interactions are very improbable, though they exist. Wikipedia has an article on this. This also makes light beams non interacting but passing through each other with just a superposition, the interactions would be happening by individual photons from each beam and would be of very low probability.
photphot
A Feynman diagram (box diagram) for photon–photon scattering, one photon scatters from the transient vacuum charge fluctuations of the other
This diagram is a recipe for calculating the integral which will calculate the probability of interaction between two photons due to the electromagnetic field. The probability is small because the vertices contribute as $(1/137)^2$ multiplicative to the integral.
Coming to gravity, we do not yet know that gravity is quantized, and has the equivalent particle to the photon, the graviton. It is effectively quantized and it is accepted that the graviton exists, but there is no final definitive theory for the quantization of gravity, proof of this is part of the current holy grail for theoretical physics.
If the graviton exists, the gravitational attraction at the photon level will be calculable by a similar diagram , where the contribution of gravity at each vertex would be exponentially small, as the gravitational constant is tens of orders of magnitude smaller than the electromagnetic constant which gives rise to the attraction at the particle level.
At best , if the two photons do scatter with a graviton intermediate, they will just change direction, but the huge probability is that they will not interact gravitationally.
How photons build up the classical beam, which is bent by large gravitational fields, is a story that needs a lot of mathematics to be understood. One has to be careful when talking of photons and light, photons are not bricks building up light, they are modeled by complicated complex functions which superposed build up the classical light wave.
Two photons cannot become "one photon" they will scatter through each other and move off conserving momentum and energy in the interaction. The scatter might be in the "attractive" direction , but there cannot be a "joining".
Photons always move with velocity c. There exists a center of mass system for your two photons, but they can never be one, because of energy and momentum conservation, a single photon has no center of mass due to its c velocity.
In view of above lets see your question:
No. they can just scatter with a very small probability due to the gravitational exchange, the electromagnetic would dominate but it will still be very small.
No, they scatter away with velocity of light c.
This cannot happen as said above.
anna v
  • 236,935
