I have seen this question about off-diagonal long range order in superfluids.
What’s the difference and the significance between long range diagonal and off-diagonal long range order?
SuperCiocia
  • 25,602
Found the answer. It means density modulation.
While off-diagonal long-range order is defined as $n^{(1)}(r,r')=\langle \psi^\dagger (r)\psi (r')\rangle$, diagonal long-range order is the special case where $r = r'$. Qualitatively, one can see that when $r=r'$ the argument of the expectation value is $|\psi(r)|^2$, i.e. the probability density of finding the particle in space. Hence, diagonal long-range order $\leftrightarrow$ density profile of the system.
rob
  • 96,301
SuperCiocia
  • 25,602
