18
Most people know the famous equation:
$$E=mc^2$$
What were his steps of thinking for this equation that helped us discover so much about our world?
Hobbs
  • 683
You can find the shortest and easiest derivation of this result in the paper where it was released by Einstein himself (what better reference can you find?) in 1905. It is not the main paper of Special Relativity, but a short document he added shortly afterwards.
A. Einstein,Ist die Trägheit eines Körpers von seinem Energieinhalt Abhängig?, Annalen der Physik 18 (1905) 639. A pdf file of the English translation Does the Inertia of a Body Depend upon its Energy-Content? is available here. (hattip: user53209.)
It is a delightful document to read. There is no dramatic references to huge power release nor anything similar. He simply states after the derivation "If a body gives the energy away $L$ in form of radiation, then its mass decreases in an amount $L/V^{2}$ (...) the mass of a body is a measure for its energy content (...) One can not exclude the possibility that, with the bodies whose energy content changes rapidy, for example radium salts, a proof of the theory will be found (...) If the theory adjusts to the facts, then the radiation transports inertia between emitters and absorbers."
Google for that short paper and see the derivation yourself, it is very easy. The Minkowsky four-dimensional spacetime had not yet been incorporated to special relativity, so the equations are formally very simple, easy to follow with little mathematical training.
Einstein's equation doesn't have a "proof" because it's not a mathematical theorem. It's a physical theory that is overwhelmingly supported by experimental data. So you could say that the "proof" is in the mountains of experimental results that agree with the theory.
To understand Einstein's motivation for developing the theory of relativity, as well as mass-energy equivalence, Wikipedia has an excellent article on the history of relativity.
Dmitry Brant
  • 2,547
I agree with Ron completely and wouldn't recommend "studying" Einstein's original papers about it. It's old fashioned and is explained much more accessible nowadays. Also there's a whole history behind the famous equation, where I gave an answer about, or rather a link in the answer here:
How to understand $E=mc^2$?
I also noticed that someone who asked a question what the physical reason is of why $c$ is squared in the most famous equation of all. Which is not fully known, but I try to explain there as well.
But so a more modern view about how Einstein realized that $E$ equals $mc^2$ is as follows:
Einstein looked at the case of an object emitting two rays of light in opposite directions. As a result, the object's motion is unchanged, since the light pressure reaction from the two rays canceled each other. However, the object loses the energy that is carried by those rays of light.
Looking at the same object from a moving coordinate system, the situation appears different. The rays of light now carry a certain amount of momentum, as measured in that coordinate system. Yet the velocity of the object itself is unchanged. Since momentum is conserved, this is only possible if the object's inertial mass has changed, and indeed, Einstein found that the change in inertial mass is equal to $ΔE/c^2$, where $ΔE$ is the amount of energy emitted in the form of those light rays.
In Einsteins paper there's no mention of (conservation of) momentum, though. Instead, he argues that the kinetic energy of the object changes relative to the moving frame, without a change in its speed. This is accounted for by a loss of inertial mass of the object in the amount of $L/c^2$, where $L$ is the combined energy of the two identical but oppositely directed light pulses.
As I understand he later used the first argument, which is more thoroughly explained in a classic book "Physics for the Inquiring Mind", in a nutshell note:
PS. The style of scientific publishing at that time was somewhat rougher than it is today (where nowadays there must first be an introduction, an elaboration and then the conclusion). Einstein started right in the middle of the story.
-1
It is incorrect to say that $E=m$ cannot be proven, it is a mathematical theorem and can be proven within the axiomatic system of special relativity. The point of experiment is to verify this axiomatic system or theory (or more precisely, to alter our confidence in this axiomatic system), but "it's all experiment" is an unsatisfying and useless answer when it comes to understanding the math. It's particularly bad in this case, because it doesn't teach you what energy is, so it's silly to say you can experimentally prove things about it.
The assumptions you need to prove this (and other relativistic dynamics) are: (1) the postulates of special relativity (2) de Broglie's relation (3) conservation laws (this along with 1 also imply the Newtonian approximation at low speeds, but it's better to list it directly, since it's where the definitions of energy and momentum come from). I mean, in principle you could use some other set of results as your axioms, but that's useless and boring, don't do it.
The proof is fairly simple. An object releases light $E$ in opposite directions, and you consider the rest frame and a frame moving at $v$. You consider a low-velocity approximation, where the Doppler factors $\sqrt{\frac{1+v}{1-v}}$ and its inverse approach $1+v$ and $1-v$. The total energy is clearly conserved anyway, so we look at momentum conservation instead -- the momentum is equal to the energy in magnitude (by a factor of $c$, but that's just 1), so we argue that the change in momentum due to the light in the moving frame of reference must be $(1+v)E/2-(1-v)E/2=vE$. So this must equal the change in momentum from the decrease in mass $m$ (the mass is moving at $v$ in the opposite direction in the moving reference frame), and we have $vE=mv$, or $E=m$.
You can also use this to prove other dynamical results, see e.g.
This is Einstein's derivation -- there's a lot of crap online, such as from minutephysics, claiming to be Einstein's original derivation, and if you believe them, I have a mass-loss bridge to sell you.
