The four axes of spacetime are $x, y, z$ and $ct$, where $c$ is the speed of light, and $t$ is time. Why is the speed of light (not any other speed) used to define the fourth axis of spacetime? If someone answers that the speed of light is the maximum speed among all speeds, such answer does not satisfy me. I would further ask: why is the maximum speed used to define the fourth axis of spacetime?
Shen
  • 1,693
Suppose in three space you want to know the distance, $s$, to some point in space $(x,y,z)$. This is simply given by Pythagoras' theorem:
$$ s^2 = x^2 + y^2 + z^2 \tag{1} $$
Now consider 4D spacetime, and ask the same question: what is the distance to the spacetime point $(t,x,y,z)$. We call this distance the proper distance (or the norm of the four-vector) and in special relativity it is given by the Minkowski metric:
$$ s^2 = -(ct)^2 + x^2 + y^2 + z^2 \tag{2} $$
Ignoring the minus sign for the moment, this looks just like equation (1) except that in addition to the three components $x$, $y$ and $z$ we have the extra time component $ct$. That's why when we are graphing points in spacetime we conventionally use the four axes $x$, $y$, $z$ and $ct$.
To a degree this is simply converting your question to a different one to because you'll now be asking: yes, but why the Minkowski metric? And I don't think there is a good answer except to say that experiment confirms that the Minkowski metric does indeed describe the geometry of flat spacetime. That's just the way the universe is constructed.
Incidentally starting from the Minkowski metric we can easily see that $c$ is the maximum speed. See for example my answer to What is so special about speed of light in vacuum?
John Rennie
  • 367,598
But $c$ is an invariant speed. Let me be clear about this, if an object is observed to have speed $c$ in an inertial reference frame then, according to the Lorentz transformation, it has speed $c$ in all inertial reference frames.
Thus, $c$ is a universal constant with dimensions of $[LT^{-1}]$. As such, it seems natural for $c$ to be a conversion factor for measuring time in units of length (or length in units of time).
Indeed, in geometrized natural units, $c$ is the dimensionless number $1$ and time has dimension of $[L]$.
Note that this does not mean that $c$ is used to "define the fourth axis of spacetime" in any way that I can think of.
The speed of light $c$ defines the scaling factor for all spacetime coordinates. We can see this by using a system of units where $c$ is a pure unitless number, usually by setting $c=1$. By imposing that $c$ is a pure number, we also establish that distance and time are exactly equivalent (time is converted into distance when you multiply by 1). So, in these natural units, space and time have exactly the same units (you can choose whether you call them units of distance or time, since those two quantities are equivalent). In SI units, this is equivalent to measuring distance in light-seconds and time in seconds, or measuring distance in meters and time in meters that light travels in a time interval.
The fundamental idea of relativity is that space and time are not distinct. Rather, they mix together as components of an overall spacetime. The fact that we have chosen different units to measure space and time is a historical artifact of our earlier belief that space and time were distinct, and therefore carries no fundamental relevance.
I believe that you should turn your question around.
It's an accident of history that we first discovered $c$ as the speed of light, but its true significance (according to SR) is that it's the space / time conversion factor.
Once that's established, it can be shown that $c$ is invariant, and that massless particles must travel at $c$.
BTW, in relativity, time is conventionally the zeroth component, not the fourth.
PM 2Ring
  • 13,541
